Hey y’all. I installed a Super E Carb over the weekend on a 94 FLSTN. Stock pipes, heads, cams… no engine mods at all. Need some advice on tuning and jetting. Can’t really get her dialed in. Starts and idles and runs. Came from S&S with a .0295 intermediate and .070 main jet. I think the main may be to small? The other issue is when I turn the acceleration pump off at idle, the engine wants to quit. My AP is only about a 1/2 rotation out current. Any further I go with the pump length, the motor gets sloppy again. Any advice would be extremely appreciated.
Positive that I have distinguished the three different adjustment screws and I have throughly made adjustments to idle speed and idle mixture at operational temperature. I agree it’s very strange how the motor acts when I shut the AP completely off.
I had to use a .031 on my 85 with a completely stock engine. I don't remember what the main is.
You sure you didn't have a vacuum leak somewhere... Hell I'm only running a .031 in my 96 in Evo.. I also have a Wego III AFR setup so I know it's right on..
I sprayed the manifold a number of times and got nothing that would indicate a leak.
Did you get this figured out. S&S carbs are my thing.
Good Good question cuz I just reread the whole thread, and if he's only out a half a turn on the air fuel idle mixture screw then his intermediate jet of an .0295 is too big... He needs to go down to a 28 but I think the 70 main jet should suffice for the rest
