Scars on Main Shaft 88 FXRS
Old Jan 9, 2021 | 08:36 PM
TwiZted Biker's Avatar
TwiZted Biker
Originally Posted by Handro
The rod comes out about 3/4 of inch. Its not tight though, it slides freely but comes to a complete stop before it comes out.
It's the multi piece rod then and mating points inside the shaft got ate up and mushroomed, won't come past the bushing in the end of the shaft. Clutch cable adjustment being too tight was the usual culprit on that failure
Old Jan 9, 2021 | 08:40 PM
86glider's Avatar
86glider
A special puller for the race and a extra deep socket for the nut, correct?
Yes, you need both.
Old Jan 10, 2021 | 12:10 AM
Handro's Avatar
Handro
I’ll need the following parts.
clutch hub and clutch
New main shaft spline type
New inner and outer primary
New starter
can use my existing chain and compensator?
anything else I might have missed?
Old Jan 10, 2021 | 07:32 AM
86glider's Avatar
86glider
I don’t think you need a new inner and outer primary or starter.As Mike stated, just the later clutch and main shaft components up to 94.
Old Jan 10, 2021 | 07:46 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
No reason to replace the primary covers or starter, unless you want to use the later design starter setup.
Old Jan 10, 2021 | 08:02 AM
t150vej's Avatar
t150vej
I'm glad Dan and 86 weighed in and confirmed what Mike said in post #4
I had '98 - up clutch basket and starter conversion in my head. That and having never converted one to spline shaft I got the OP confused in post #10, so my apologies for that.
Old Jan 10, 2021 | 08:41 AM
Handro's Avatar
Handro
I might as well if I have everything apart. The starter was beginning to give me issues.
Old Jan 10, 2021 | 12:19 PM
mike131's Avatar
mike131
I might as well if I have everything apart. The starter was beginning to give me issues. If you want to go that route updating the primary covers??, the newer starter set up is much better, and newer clutch primary set up 95-2007 which is also better, but you will also have to deal modifying the transmission case starter hole!
Old Jan 10, 2021 | 12:21 PM
mike131's Avatar
mike131
It all depends on how much you know on how far down the rabbit hole you want to go?
Old Jan 10, 2021 | 12:57 PM
TXFXR's Avatar
TXFXR
This ^
We met the other day and it's really how much you want to do/spend. Mike is really knowledgeable and has gave you some really good routes you can go.
Don't worry about the race, a dremel can easily get that out and it doesn't matter if you hit the shaft because well, it's f'd anyways haha. As far as the socket for your front sprocket and trans I can get you those easy, takes no time to do both.
If you keep your starter set up you can rebuild your bike with a splined shaft and clutch components for reasonably cheap.
riod34
Nov 6, 2015 08:12 AM
slburgie
Jul 5, 2014 07:47 PM
Johnny K
Aug 2, 2013 04:48 PM
ThorpeFLH
Apr 3, 2013 08:20 PM
kingzy
Ironhead
Apr 30, 2006 10:14 PM
