Timer Cover
Old Jan 21, 2021 | 07:18 PM
TedMan's Avatar
TedMan
Default Timer Cover
I don't know why it took me so long to realize, but the plain chrome timer cover on my 96 flstn has mounting screws at the 3/9 position, not 6/12. I removed the outer cover (3/32 hex) and there are vertical holes, as well, on the inner cover. Was this a common mod, drilling and tapping for horizontal covers? Just curious. Thanks for any insight.
Old Jan 21, 2021 | 08:08 PM
GOGOBECK's Avatar
GOGOBECK
The stock timing cover was pop riveted at 12 and 6. Most came with a V2 embossed aluminum cover. Most have been changed out through the years, It’s cool these days when I see one in its original state.
Old Jan 21, 2021 | 08:10 PM
TedMan's Avatar
TedMan
Found part of the answer. This diagram shows 4 holes in the inner cover:
https://partsfinder.onlinemicrofiche...%20GEAR%20SIDE
However, this implies that the inner cover is not attached to the gasket, and the cam sensor. Is this an issue?
Old Jan 21, 2021 | 08:16 PM
96Heritage's Avatar
96Heritage
Something like this?
Old Jan 21, 2021 | 08:20 PM
CoolBreeze3646's Avatar
CoolBreeze3646
See this diagram, shows the gasket and screws holding it on. Inner timing cover goes against the gasket the outer cover is mainly for show.
Old Jan 21, 2021 | 08:28 PM
TedMan's Avatar
TedMan
I would love an NOS v2 cover. My rivets are long gone. I have s3 cams, se ac and se ignition. I'm just wondering about the inner cover not being attached to the outer cover.
Edit: inner cover not attached to the gasket.
Old Jan 22, 2021 | 04:30 AM
TedMan's Avatar
TedMan
Found the answer in this thread:
https://www.hdforums.com/forum/gener...ing-cover.html
The chrome screws on the outer cover are long enough to go all the way through the inner cover and into the screws that hold the sensor plate.
Old Jan 22, 2021 | 06:40 AM
Architect's Avatar
Architect
HD sells the rivets if you want to get rid of the screws for a stock look.
Old Jan 22, 2021 | 07:52 PM
TedMan's Avatar
TedMan
Ok, last question. Looking at the inner cover, the 3-9 position accepts a screw, but the 6-12 position is not threaded. How can I mount an Evo designed (vertical) cover when there are n threads to screw into on the inner cover. This is probably obvious but I appreciate any feedback.
Old Jan 23, 2021 | 10:45 AM
t150vej's Avatar
t150vej
You need special rivets that aren't too hard to find. Most dealers probably still have them. Part# 8699
They are called "sealing" rivets or closed end rivets and can be found at some parts stores especially if they stock body shop supplies.
The head of the mandrel is encapsulated in the rivet so when it "pops" off, it remains. A regular pop rivet will work, but if the remaining part of the mandrel vibrates loose and falls into the timing sensor area, it could be bad.
Example:
