Adding a mechanical speedometer
Old Jul 9, 2021 | 11:44 PM
Ozark Joe's Avatar
Ozark Joe
Default Adding a mechanical speedometer
Hey guys I'm wondering if y'all have came across a mechanical speedometer that mounts to the risers or handlebars? My electronic one that came with the bike when I bought it took a dump. So I'm really like to put on a mechanical speedometer since the speedometer drive on front wheel is still present. Also anything I need to be aware of when looking?
Old Jul 10, 2021 | 04:51 AM
IronAss's Avatar
IronAss
A quick search found this one. I'm sure there are a few more.
https://www.ebay.com/itm/Drag-Specia...-/350908299941
Old Jul 10, 2021 | 06:46 AM
Ozark Joe's Avatar
Ozark Joe
The thing that is throwing me off is ratios. 2/1 and 1/1 I’m not sure if that should be accounted for.
Old Jul 10, 2021 | 09:15 AM
IronAss's Avatar
IronAss
You'll need one the same ratio as your drive unit I assume and I have no idea what drive unit you have.
Old Jul 10, 2021 | 10:11 AM
Ozark Joe's Avatar
Ozark Joe
I haven't an idea. The bike is a hodge podge of parts. I'm wondering if replacing the drive would take away the doubt.
Old Jul 10, 2021 | 10:14 AM
IronAss's Avatar
IronAss
Were it me. I would just buy the speedo and a drive unit together and be done with it.
Old Jul 10, 2021 | 01:27 PM
RANGER73's Avatar
RANGER73
I don’t recall my drive until being labeled and it does make a difference on what you use. They have to match.
So like IA said, buy it as a package.
Old Jul 10, 2021 | 09:26 PM
rizzo's Avatar
rizzo
There are basically 2 drive ratios - one for 21" wheels and one for others. Go to DK or JP and look at the fitment chart pick the one that best fits your bike. The speedo should not matter, the ratio is in the drive. Your rotor will need a notch and you'll probably need to check the spacer and rotor alignment on the left side. Look at someone elses bike if it's not obvious.
Old Jul 10, 2021 | 10:25 PM
TwiZted Biker's Avatar
TwiZted Biker
Late as yours is I believe it has that goofy 2240/60 drive unit, it'll make most aftermarket mechanical speedo's read about 10-15 mph off. That can be swapped for one that matches whatever speedo get, just have to match which drive side and the spacer length the stock one had.
The ratio will not be 1/1 as that's the old trans drive gearing for the early shovel & pan days. Front wheel units are 2/1 or 2240/60.
Old Jul 11, 2021 | 09:08 AM
IronAss's Avatar
IronAss
Hey OP. If you’re planning on loosing the electronic speedo, I just saw this in another thread. See post#4. https://www.hdforums.com/forum/touri...uit-today.html
JoeyC013
General Topics/Tech Tips
Sep 29, 2015 10:27 AM
p51bombay
Mar 19, 2015 04:16 AM
Dustmaker
Jun 7, 2011 09:06 PM
stumpworks
VRSC Models
Mar 24, 2010 07:38 PM
HimeHog
Apr 29, 2008 08:40 AM
