Engine Temp Sensor
Old Jul 24, 2021 | 12:31 PM
kykingfish's Avatar
kykingfish
1st Gear
Default Engine Temp Sensor
98 electra glide FLHTCI. Bad engine temp sensor part # 32446-95. Discontinued by harley and not able to find aftermarket. ECM shuts bike down. Any work around or suggestion to find replacement
Old Jul 24, 2021 | 12:51 PM
Dr.Hess's Avatar
Dr.Hess
Try to find it New Old Stock. The dealers can look it up across their networks. Last I recall, there were 2 dealer networks, so if you find a dealer in each network, you would search the whole country.
We had a discussion some time ago. I made some suggestions on fabricating your own from a few dollars worth of parts. Some google-fu should turn up the thread.
Old Jul 24, 2021 | 01:20 PM
WP50's Avatar
WP50
I think there is an aftermarket one.
Do a search with the HD part # was how I found one for a later model tho.
WP
Opps that 98 looks a bit different as well
I'll try for tho
Old Jul 24, 2021 | 02:03 PM
WP50's Avatar
WP50
Looks like he may need to do this
Dang
WP
Old Jul 24, 2021 | 02:37 PM
t150vej's Avatar
t150vej
32446-95A is the updated number and available from MoCo. Don't know about aftermarket.
Old Jul 24, 2021 | 02:38 PM
WP50's Avatar
WP50
Just to throw stuff at a wall
Could an extension be machined to screw into the head and the other end made to accept a 32446-99.
Not sure of the room to do this. Have only seen one of these motors in real life.
WP
Old Jul 24, 2021 | 04:25 PM
kykingfish's Avatar
kykingfish
1st Gear
Found a standard motor TS-432, fits 2000-2005 lincoln ls, wonder if this might work. Looks close to sensor I pulled out. About 1/2 price at auto parts store
Old Jul 24, 2021 | 04:45 PM
WP50's Avatar
WP50
Might be a long shot on the connector end.
That sensor would need to be pretty close in the resistances it can measure.
Not sure how to make the comparison between the 2 Ummmmm
Most parts places hardly accept returns on things like this. Is worth 50 bucks to find out?
Old Jul 24, 2021 | 05:39 PM
carlgrover's Avatar
carlgrover
I've searched high and low for a replacement head temp sensor. Quite a ways back someone mentioned that the temp sensor was the same as the one on some Italian bike. I've scoured several Italian bike parts places looking for one and have so far come up empty. The one shown from SMC is close but I'm betting it might not work. It's a coolant temp sensor.
carl
Old Jul 24, 2021 | 05:46 PM
kykingfish's Avatar
kykingfish
1st Gear
Thought someone has to make them for harley but probable not worth $50 to find out, unless last resort. Found 32446-95a at a dealer in PA. Will probable go that way. Thanks for the replys.
