Evo swap.
Old Aug 10, 2021 | 07:21 PM
Bamaharley1's Avatar
Bamaharley1
Stage I
Default Evo swap.
First post here.
I have a 93 softail with an evo motor.(carbureted)
I have a line on a 97 electra glide with no motor on it currently. (Was a fuel injected evo motor)
Will my carb evo bolt right up, to the frame tranny, etc.? I do understand that softail is a rigid mount and the glide has rubber mount. If it mounts, would i need to use my wiring harness from the softail, or is everything else plug and play??
Thanks in advance,
Kevin
Old Aug 14, 2021 | 02:34 PM
90Ultra's Avatar
90Ultra
Not sure, but my vote is find a motor for the Electra Glide and keep both!! I have an '89 Softail and a '97 Ultra.
Old Aug 14, 2021 | 02:38 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Find an engine for the Electra Glide and leave the Softail be.
Old Aug 14, 2021 | 10:43 PM
1997bagger's Avatar
1997bagger
The engine will bolt in, carb will work, Twin Cams use a counterbalanced engine for softails, difference in Evo is the EFI engine has notches cut in the flywheel and a crank sensor. Issues will need addressed is the EFI tank needs converted to single outlet thru a Pingel adapter system including all the fuel tank inner items removed and cut 1 steel line out. Common conversion is change the EFI ignition module to a non EFI system plus a carb rotor with coil, ECM and wiring harness can be removed BUT CAN still use the EFI ignition system with ECM if desired to fire the spark, a check engine light will be present at all times because the ECM won't be reading a injector pulse.
Hardest part is the fuel tank line conversion, Ultima ignition system comes with everything you need including a wiring harness, main power for the ignition is a white wire with black tracer under the right side fuel tank, it is the ignition control switch wire for a carbed engine. Tach wire will be a pink wire exiting out the back of the fuel tank, ECM is signaling the tach now, the Ultima ignition module has a wire coming out of it to replace the ECM signal wire. The EFI coil is a single fire but uses a sealed connector body, requiring replacement or wire splicing to keep it.
Note: your carb engine harness on the softail will work but the harness is obsolete to replace, pick your poison.
Old Aug 15, 2021 | 07:38 AM
Dan89FLSTC's Avatar
Dan89FLSTC
The OP wants to swap and Evo for an Evo, not a TC.
Old Aug 15, 2021 | 08:07 AM
1997bagger's Avatar
1997bagger
Used for reference, find something else to be negative about.
Old Aug 15, 2021 | 08:17 AM
Dan89FLSTC's Avatar
Dan89FLSTC
You started talking about TC engines, after that I didn`t know if the information you were giving was about Evo or TC.
It had nothing to do with being negative, I just was confused on which engine you were talking about for the rest of your post.
Old Aug 16, 2021 | 10:39 AM
IBDAGRIZ's Avatar
IBDAGRIZ
Originally Posted by Bamaharley1
First post here.
Thanks in advance,
Kevin
You'll just need to convert the carbed motor to EFI in the new bike. Can get expensive if you have to find all the parts (intake and sensors) for it. Probably about the same cost as converting it over to carb on the new bike.
Mounting it will bet he easiest part. Just find the mounting parts from a list.
Griz
Abandoned
EVO
17
Jun 17, 2021 04:05 PM
LoBoT
EVO
59
Jul 10, 2014 10:49 PM
mattlal
Jul 1, 2012 11:41 PM
bikerlaw
EVO
Aug 30, 2011 08:29 PM
graultytc88
EVO
Jan 18, 2008 03:04 PM
