Transmission Issue
Old May 31, 2022 | 12:22 PM
  #91
brakeless's Avatar
brakeless
No, the ball and ramp I am running is original `89.
The larger ball bearings are in the trap door, `99 and later used the larger ball bearings, the inside diameter of the bearings remained the same.
Must have been someone else. My mind is shot right now. Meds are making me forget stuff. But I went to 10mm ***** in ramp to increase lift slightly and so did someone else.
Old May 31, 2022 | 01:13 PM
  #92
mike131's Avatar
mike131
The Muller power clutch works real well, but a little pricey, have one in my fxr, clutch pull is easy with only two fingers, https://www.denniskirk.com/muller-mo...prd/382823.sku
Old May 31, 2022 | 01:25 PM
  #93
Yankee Dog's Avatar
Yankee Dog
98hotrodfatboy has 10mm ***** also… 😜
Old May 31, 2022 | 01:53 PM
  #94
brakeless's Avatar
brakeless
Yeah they work great. But they're overly proud of their stuff. That really shouldn't cost that much.
Old May 31, 2022 | 02:11 PM
  #95
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
The price is ridiculous, the oem parts were about 10 bucks each.
Old May 31, 2022 | 04:25 PM
  #96
mike131's Avatar
mike131
That is so true especially when it doesn't even come with those "*****" lol, you have to use your original ones!
Old May 31, 2022 | 04:33 PM
  #97
98hotrodfatboy's Avatar
98hotrodfatboy
Yeah I always had bigger *****.... LOL.. But they definitely to create more separation in the disc's...
Originally Posted by DeputyLoud
So it's ok to use the 21 degree ramp with the '91 clutch pack?
And thoughts on the '04 trap door on a '91 case?
Yes it's ok to use the 21* ramps but keep in mind that they will not make the clutch pull easier.. They will give a little more separation to the clutch pack but also stress the clutch spring more which will make it feel like a harder pull on the lever... As for the trap door I do not have an answer.. Sorry....
Old May 31, 2022 | 04:39 PM
  #98
Yankee Dog's Avatar
Yankee Dog
Here is the post to 98hotrodfatboy and the famous 10 mm *****, it's good info. I just never got around to ordering them, curious if your still using them on your bike??? Any negatives??
https://www.hdforums.com/forum/evo-c...vo-clutch.html
Old May 31, 2022 | 04:46 PM
  #99
98hotrodfatboy
Thanks YD, not sure about being famous like IHOP Pancakes but I've not had any issues at all.. Shifts are still effortless.. Even when Power Shifting I've never missed a gear.. And we all know about the "3 more HP".. LOL..
Old May 31, 2022 | 05:51 PM
  #100
brakeless's Avatar
brakeless
I did the 10mm ***** in my '04 with a Energy One clutch. Got the ***** from Mcmaster Carr for around $9 for a 10 pack. No problems at all. I just looked up some of my notes. The stock ball is .375" and the 10mm ball is .394" so .019" bigger. My own notes are even hard for me decipher now but it looks like it gave me an increase of 0.127" lift at the plate. Or 0.869" total lift. I gotta start making better notes! LOL!
