Transmission Issue
Old Apr 30, 2022 | 09:46 PM
  #81
0maha's Avatar
0maha
No need for dope on the gaskets, and that bearing indeed is a loose fit.
Old May 30, 2022 | 08:06 PM
  #82
DeputyLoud's Avatar
DeputyLoud
So It's been a minute. Summer is here and life if getting in the way. Time is always a precious commodity. Did get a nice ride in yesterday.
Thx to the long holiday weekend and a vac day last Friday, I was able to put a good day into this today.
Things went pretty well. I got the bearings replaced in the new '04 trap door, and installed the '04 gear set. '04 shifter forks and drum assy are also now in. All new gaskets installed and buttoned it up with top cover. Still have to do the side cover install. Noticed tho that the ramp assy that connects to the clutch cable is dif between the '91 & '04. The one that came with the '04 has 21 degrees stamped on it and the '91 has 18 degrees stamped. What's the dif and which should I use?
Another concern is that the edges of the '04 trap door do not line up exactly with the housing of the '91 trans case. Should I have used the trap door from the '91? Thinking it's fine and just a cosmetic thing. Everything seems to function properly thus far.
Old May 30, 2022 | 08:24 PM
  #83
brakeless's Avatar
brakeless
The more degree the easier the pull. Therefore, 21⁰ is a "easy pull". But that being said, it also has to move a bit further in order to complete lift. Some have trouble, some don't. Depends on the clutch setup.
Old May 30, 2022 | 08:52 PM
  #84
DeputyLoud's Avatar
DeputyLoud
Thx. Clutch setup will stay stock for now. See what the final adjustment brings me. Think I will try the '04 (21 degree), the current clutch pull always did feel somewhat heavy.
Old May 30, 2022 | 11:57 PM
  #85
brakeless's Avatar
brakeless
Lots to factor. The diaphragm spring is often thought "the heavier the better" but unless it's slipping with high hp it's overkill. Especially on your hand and forearm!
Old May 31, 2022 | 07:02 AM
  #86
DeputyLoud's Avatar
DeputyLoud
So it's ok to use the 21 degree ramp with the '91 clutch pack?
And thoughts on the '04 trap door on a '91 case?
Old May 31, 2022 | 09:49 AM
  #87
brakeless's Avatar
brakeless
I can't say for sure as I've never done it. On my '93 I have the stock ramp with the Burley EasyPull and that made it a one finger pull. On my '04 I did use the 21⁰ ramp with the stock clutch and that was about a 30% reduction in effort. As for the trap door, I really don't know if it will work. Maybe one of the Transmission experts will chime in.
Old May 31, 2022 | 09:55 AM
  #88
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
I have a 1999 touring trap door on my 1989 softail transmission case, other than having to drill and tap it for the softail type drain plug it was plug and play.
Old May 31, 2022 | 10:23 AM
  #89
brakeless's Avatar
brakeless
Atta Boy Dan! I was actually thinking of you when I said Transmission Experts. LOL! Didn't you also use larger diameter ball bearings in the ramp assy?
Old May 31, 2022 | 12:04 PM
  #90
Dan89FLSTC's Avatar
Dan89FLSTC
No, the ball and ramp I am running is original `89.
The larger ball bearings are in the trap door, `99 and later used the larger ball bearings, the inside diameter of the bearings remained the same.
