Transmission Issue
Old Mar 27, 2022 | 08:41 PM
t150vej's Avatar
t150vej
Originally Posted by DeputyLoud
Nothing jumped out at me with the front pulley. It's still in place. Suppose I should pull that for further inspection, before cracking open the trans.
I want to guess it's a stripped front pulley, but that's only a guess. Pull the top off the trans, pull the shift drum, slide it into 2 gears. That will lock the main drive gear - makes it easier to get the big nut off the pulley.
If the pulley is stripped, the gear set is coming out regardless to replace the main drive...
Old Mar 28, 2022 | 01:56 PM
GREENOHAWK69's Avatar
GREENOHAWK69
On the topic of the sway bar removal and the bike yr/mileage. I've never pulled one. What is recommended to be serviced while that is out? (ie...bushing replacements ect). Preferred brands? I usually try to stick with oem parts when affordable. Unless aftermarket is obviously a better choice.
Sway bar removal? Did you mean swingarm? If yes, why?
Old Mar 28, 2022 | 02:03 PM
brakeless's Avatar
brakeless
Maybe that's the problem, his bike has a "Sway Bar"...
Old Mar 28, 2022 | 03:53 PM
Yankee Dog's Avatar
Yankee Dog
I'll take stripped pulley for a $1000 Alex
Old Mar 28, 2022 | 04:11 PM
t150vej's Avatar
t150vej
And if it is a stripped pulley, it's safe to say -
Old Mar 28, 2022 | 04:16 PM
mike131's Avatar
mike131
I thought Alex was Jeopardy?? lol
Old Mar 28, 2022 | 05:01 PM
t150vej's Avatar
t150vej
Who cares...
Old Apr 2, 2022 | 05:39 PM
DeputyLoud's Avatar
DeputyLoud
Yup it does not have a sway bar, lol. And at this point I think I'll take that bet on the issue being a stripped front pulley as well. Although I somewhat thought that even without removing it, it would be more obvious? But the symptoms match that diagnosis at this point.
Got the trans top and side covers off. Shift drum assy and forks are out. They seem straight without obvious wear. All seems ok to my novice eyes on first inspection. No obvious metal in oil. So seeing as I don't have the main shaft bearing race puller, I just ordered that and the 1 7/8" socket needed to get the pulley off for inspection. There goes another hundy. One way or the other as you guys have said, it all needs to come out.
Old Apr 2, 2022 | 07:40 PM
DeputyLoud's Avatar
DeputyLoud
Still curious on the false neutral issue I've had since I have owned this bike. The pulley wouldn't cause this. And from what I've seen thus far, I can't explain it. But as long as I am in this deep, should I replace the shifter cam and forks? Maybe update the spring?
That is if I don't find a more obvious issue in the gear set when pulled.
Old Apr 2, 2022 | 08:12 PM
Yankee Dog's Avatar
Yankee Dog
Take a good look at shifter pawl and how to properly adjust it. Since cover is off and drum/forks are out look at the gear dogs for anything ugly.
