1995 FLHTCU brake light problem
When I turn the ignition switch on, the running light is on. Then if I push either brake, the brake light comes on and won’t turn back off. If I turn the ignition switch off and back on, the running light is on but brake light is back off until I push a brake again. I’ve taken the master cylinder off and operated the handlebar switch by hand to check if the lever was the culprit but I’m getting the same results.
Any ideas? Thanks in advance
Rear brake switch is a pressure switch in line on the rear brake line.
Both activate the brake light relay.
So start by pressing on the rear brake peg, and see if the brake light is working correctly to start with.
Next, pull the front brake lever and see if it working correctly. Note, make sure to push the lever all the way open to see if that solves the problem,
If the problem is the front lever plunger switch, may have screwed it up the front brake light switch when you put the lever back on.
As for brake relay, could be sticking and needs to be replaced, but since you where working on the front end alone, by guess is that you did not put the lever back on correctly, and broke the front brake switch.
I can hear the relay click once I press the brake. It is possible that the relay is bad? It will engage but not disengage when the brakes are released.
To understand a relay, you have a coil side and the contractor sides.
So contactors 85 and 86 are your coil terminals. When the brake plunger/pressure sensor are activated, allows continunity across them, which sends power to the coils side of the relay to fire it contractor lever.
So since we don't use the normal closed contractor, but the normally open contractors of 30 to 87A to turn the rear light bulb on, the quick way to check the relay, is to pull it then put a meter on the relay connector pins 85 and 86. When either of the brake lever/pedal sensor are used, should have 12 volts across these pins, and when you let off on the lever/pedal, should lose the 12 volts across these pins. If this is the case, then problem is in the relay with either broken lever spring, or burnt contact pads that are casing lever binding to not allow the lever to release when the coil is de-energized.
If when you let off the lever/pedal, you don't lose the 12 volts across pin 85 and 86, then the problem is back in the lever/pressure switch/there wiring isntead.
Simply pressure switch, and in the case of the front switch, wired through what would be a normal closed circuit that lever pressure with the lever not touched (pushing the plunger inward), will keep the continuity through the switch disconnected,
Note, rear brake pressure switch is wired backwards, hence using it normal open side for wiring, and when it sees pressure from the brake fluid pressure to push it's plunger outwards, makes continuity through the switch instead.
So to check the brake and pedal sensors, just use a meter across the wires with the meter set to ohms, and with the lever out, the brake pedal not touched, should have no no continuity across the wires. Pedal pressed, lever pulled, meter should show a resistance reading, and releasing the pedal/lever, meter should back to showing no continuity through the wires.
