EVO ultra charging problem
Old Jul 5, 2022 | 10:14 PM
cdarthvader's Avatar
cdarthvader
6th Gear
Default EVO ultra charging problem
I'm at my wits end with this bike and charging. It has a new battery, new regulator, new stator, and new rotor and I am still not getting a charge. Stator is checking out good, regulator checked out good and is showing 14 volts at the lead with it not hooked to the bike. When I hook it to the bike its not charging. showing 12.9 volts before start, 12.3 while running and not moving from that. Circuit breaker is showing good on both sides, I even ran the regulator wire to the positive side of the battery to bypass it and still no joy on charging. What am I missing?
Old Jul 5, 2022 | 10:31 PM
TriGeezer's Avatar
TriGeezer
Welcome.
Follow the diagnostic procure at the top of the electrical sub forum. And make sure to check continuity and resistance of all the wiring.
Old Jul 6, 2022 | 01:34 AM
t150vej's Avatar
t150vej
Are you reading the voltage (12.9/12.3) on the fairing gauge or on a separate voltmeter at the battery?
Just because a battery is new doesn't mean it's good and more importantly, these factory volt gauges are not the most dependable. If fairing gauge is reading 12.9 with engine off/switch on, that's suspect.....
Old Jul 6, 2022 | 03:54 AM
guido4198's Avatar
guido4198
Battery cables can harbor internal corrosion above the lugs. If the cables are original, it's a cheap replacement. They can be good enough to show continuity with a meter...but still be a source of problems.
Old Jul 6, 2022 | 05:09 AM
RANGER73's Avatar
RANGER73
has to be above 1200RPM (might be more) Harley's don't charge at idle.
Sounds like a short in the battery.
Old Jul 6, 2022 | 07:17 AM
cdarthvader
6th Gear
That’s with a volt meter, the gauge is showing 10 volts and never relied on it anyway. This was the second new battery because I’ve thought the same thing and still the same problem
Old Jul 6, 2022 | 07:19 AM
cdarthvader
6th Gear
Originally Posted by TriGeezer
Welcome.
Followed the diagnostics and these all are new parts , including a second new stator second new regulator and second new battery. Everything is showing it should be working it just isn’t. I know there has to be something I’m missing just can’t figure this one out.
Old Jul 6, 2022 | 07:20 AM
cdarthvader
6th Gear
I had changed those to larger gauge about 3 years ago. Maybe they could be corroded by now? I’ve checked the connections and they are all good.
Old Jul 6, 2022 | 07:26 AM
cdarthvader
6th Gear
with the regulator hooked up as it’s supposed to at 2000 RPMs it shows 12.3 volts and if I rev it higher it drops to 12.1. This is the second new battery because I thought the same thing. I’m at a loss.
Old Jul 6, 2022 | 07:38 AM
yellowstone kelly's Avatar
yellowstone kelly
I'm not familiar with an Ultra's wiring specifically, but a voltage regulator usually needs to be well grounded to work correctly.
No paint, rust, or corrosion wherever it grounds to.
Missing, loose, or poor ground connections can cause weird electrical sh*t to happen on a vehicle or trailer.
