Callapsed lifters
Old Aug 8, 2022 | 11:02 AM
98hotrodfatboy's Avatar
98hotrodfatboy
One thing that people tend to forget is that when you manually pump up your lifters and install them and then adjust the front cylinder pushrod, it's actually pumping that lifter down and then you turn the motor over to adjust the rear cylinder then that front valve spring pressure is going to pump down the front lifters again. This is why it can take some time to pump them back up.. So when you know you are correct in your adjustment procedure and start the motor and get some noise, sometimes you just have to be patient till they pump up.. Unless it's really lose and loud. Then you might have to go back in and readjust.. I've had lifters take a 15 minute ride to quiet then down totally.. I always set preload from zero lash (top down) at TDC...
Old Aug 8, 2022 | 07:36 PM
SparkyD's Avatar
SparkyD
I tried running the motor 3 times to pump the lifters up. Those 2 bad ones just collapse further like there is no spring in them at all. Bike would barely run with throttle wide open and was staying around 2500 rpm. And it was horrible. Could not keep it running for even a full minute. I put the OEM lifters back in for now. Going to invest in some S&S lifters and quickie pushrods.
Old Aug 8, 2022 | 07:41 PM
98hotrodfatboy
Yeah those 2 lifters were real bad.. Going to the S&S is a good choice.. I only posted what I did because sometimes some people need to give it a little time.. it just the way it is.. But your 2 are beyond the point of no return.. I never had a plunger stick like that..
Old Aug 8, 2022 | 07:45 PM
SparkyD's Avatar
SparkyD
If they are Fueling or V-Twin somebody needs better quality control in their factory
evangenj
Engine Mechanical Topics
Jun 13, 2023 08:05 AM
89FLHTC
EVO
11
May 7, 2016 07:16 AM
jammerx
Sep 12, 2014 03:55 AM
Rui Frederico Basto
Exhaust System Topics
Jul 27, 2012 05:31 AM
Turbo ray 44
Apr 12, 2011 12:33 PM
