93 low rider electrical gremlins s
Old Sep 5, 2022 | 12:29 AM
provie97's Avatar
provie97
Stage IV
Default 93 low rider electrical gremlins s
What’s happening fellas,I’m new to HD forums and the owner of my second harley but first one I’ve worked on besides maintenance. It’s a 93 dyna low rider and I got it with all of primary and secondary disassembled and missing a good many parts in between. I’ve finally got everything together and ready to run, I hit the starter button and clutch cable burns up ( after a few attempts of pushing the button before I saw the smoke coming from the cable). But anyway, I’ve read the posts about the ground issues it could be. But when I put a ground from starter bolt to frame, it arced off. When I put a ground from starter bolt to negative post on battery. Burnedthe wire up. This is while hitting starter switch. I couldn’t find a ground strap and don’t know if my bike came with one and needing much appreciated guidance. Thanks in advance. (Ps. Could the front blinkers not being mounted but electrically hooked up be an issue?)
Old Sep 5, 2022 | 06:13 AM
Yankee Dog's Avatar
Yankee Dog
What gauge wire/cable are you using that is "burning off"? Start with the basics below:
You should have a cable from battery negative post to the a bolt on the frame. Another cable from one of the starter mounting bolts to the same bolt on the frame (or right next to it). The frame bolt for the cables is just above and to the right of the starter. The cables need a good clean solid connection. Check the cables for continuity.
I think factory is 6 gauge but 4 would be better if your replacing with new. In a pinch and while the quality is less than desirable, something from the auto chains would work for a temporary fix.
You also need look for a (black about 16 to 18 gauge) ground jumper wire going from frame to front triple tree and a black jumper from triple tree to to handle bar riser bolt.
Check starter relay. It is a bosch style cube relay is the fuse box location. It's best just to replace it.
Once that is done, if the problem persists, start looking for dead shorts.
Old Sep 5, 2022 | 08:16 AM
t150vej's Avatar
t150vej
Wasn't sure exactly where the ground points were, so waited till someone else got that right for you. Thanks YD.
Assuming the battery cable ground connections are correct, clean and tight, the more I read about how it "lights up" everything, more I'm leaning to a short, probably in the solenoid.
If you can, take the short cable (from the solenoid) off of the starter motor and insulate it. Try the start button and see if you get similar or same results. If yes, then you can bet there is a short in the solenoid. They can usually be repaired if it's a damaged insulator. And could be the insulator on the motor stud itself.
Old Sep 5, 2022 | 08:44 AM
0maha's Avatar
0maha
On your Dyna, the entire drivetrain (engine, trans, primary, swingarm) is vibration isolated from the frame, and therefore also electrically isolated. There needs to be a ground strap from the drivetrain to the frame.
The fact that you ended up grounding through the clutch cable is consistent with a missing ground strap.
Old Sep 5, 2022 | 03:52 PM
Yankee Dog's Avatar
Yankee Dog
Agreed. The ground from the negative terminal at the battery goes to the frame near the starter bolts(basically on the frame but behind the fuse box). The battery and battery tray needs to be removed in order see and access where the actual negative cable connects to the frame.
There is also a jumper cable that goes from one of the starter bolts to the frame pretty close to the the negative cable attachment point. I think some years the cable eyelets share the same bolt. It has a pretty large loop to prevent work hardening of the copper because the engine does move on the rubber mounts.
The engine is actually grounded right there at the starter bolt. That ground carries thru the primary and the connection points of the primary bolts provide a ground for the trans and the engine. Your primary is one big electrical connector for ground.
Old Sep 5, 2022 | 05:33 PM
provie97's Avatar
provie97
Stage IV
Thanks everyone for the info. I’m about to put larger ground wire to the spots recommended and also a ground strap. I’ll let y’all know what happens
Old Sep 5, 2022 | 11:33 PM
provie97's Avatar
provie97
Stage IV
I’m gonna have to check the starter out. I had to tear it down and clean the gears that were rusted up. Thank you.
Old Sep 6, 2022 | 08:49 AM
Racepres's Avatar
Racepres
Absolutely Typical..
Also
Too small wire Gauge...or low voltage at battery, will cause Heat... Lots of it.
Garry81FXB
Shovelhead
21
Mar 27, 2013 02:57 PM
HDrider59
Jul 29, 2012 11:25 AM
HD101st
Jul 23, 2010 07:02 PM
Derv
Jun 29, 2010 01:04 PM
ragingbull
Apr 2, 2007 11:17 PM
