EV13 in ‘93 Dyna - looking for others with the same setup
I’ve seen a lot of thumbs up for the EV13, but mostly for touring bikes. I’m running stock gearing (3.37 final) - wanted to see who else has a Dyna with an EV13 cam and what your experience has been. I’m looking to make this a long distance bike; I’m not much of a racer type, but want to be able to pass without a mile of highway and a prayer while doing it.
So far, I have been on the fence about shaving the heads - if I do, I won’t go much over .035 and throw in a .30 cometic head gasket to raise the compression a bit, but that’s about the extent of it. Toyed with an S&S Super E but since I’ll be doing some touring (and hopefully riding to Sturgis next year) I want some altitude compensation, which prolly means the CV carb it the way to go.
Any other thoughts? Long, rambling late night post that took a paragraph to get to the point ….
The ev27 or the evl3010 would be better suited for your lighter bike. Especially if your considering touring. You will still have some cam "left over" when cruising 80 mph on the highway. You will also have plenty of passing power with or without a downshift. The ev13 is better suited towards the earlier portion of the power range. It's still a good cam but my thoughts are the 27 or 3010 would be better suited.
Consider shaving/truing the base of your cylinders .010. Along with the .030 head gaskets, it will keep your chances of "ping" down, while improving your squish (quench) fuel burn efficiency as well as boost compression just a touch. Keeps you in the "no need for premium fuel" range. Trueing the cylinder bases and using Cometic SLS base gaskets also eliminates the dreaded cylinder base gasket leak that is prone to these engines (fairly common).
There will be no need to shave the heads at all after the above mods, but then again don't totally discount shaving the heads a little. Do some homework first about shaving the heads.
The above set up is what I have done to my engine after some recommendations (see my signature) from some very experienced members here, and along with those recommendations and lots of homework, it is very rideable, fun to ride, feels right, mild mannered with an even temperament. Not fussy to fuels, does what I want. It is a respectable ride with no questions about durability/longevity.
It's an evo so there are better engine choices for winning races. But if you want to make some improvements to a tried and true good solid platform engine (our evo engines) that is still easy to work on, then consider the above.
And if you're going to shave the heads you better get a set of decent adjustable push rods and you might as well change a lifters..
Yeah, it falls off at higher RPMs if I am feeling frisky and get on it a little bit, but it’s still performs well.
About 15 years back, my dad put a Crane Fireball 310 in this bike, and pulled it back out shortly after. It lost too much low end grunt for his liking, but the good news is the adjustable pushrods are still there. Unfortunately, so is the original cam bearing and lifters so those are on the list.
@ YankeeDog, I have been on the fence between the EV13 and EV27, but I like grunt down low, and my riding style typically avoids the major highways. I don’t expect to see interstate speeds on a regular basis, and if I do I’m content to cruise in the slow lane. Haven’t ruled out the EV27, but leaning towards the EV13 as it seems suited to my riding style more and is a bit milder (but still miles better than the stock N grind). Definitely appreciate your feedback though, and I may very well go that route.
I mostly ride the Road King solo with nothing in the bags so not a massive amount heavier than a Dyna etc. I push it hard through the mountain roads and the EV13 excels at that. Plenty of grunt coming out of the corners on steep uphill runs where the stock cam had it just sitting there chugging away like a chaff cutter with no pick-up. And it will still cruise at 80-100mph too. Not too much left after that though. A bit maybe but I never tried it too hard. Pushing that barn door windshield through the air at 100mph is enough for me and the old bike, regardless of cam.
I have no experience of the EV27 so can't compare the two.
the drag pipe crew is always used the 45 as it sounded like a hemi with - 2 - 4 barrel carbs drag car and pulled hard
while i agree with the machining the base of the jugs to set them flat again - dont machine the heads or the jug tops use the 030 cometic head gaskets and the cometic base gaskets
I don't know how finely tuned my butt dyno is, but this EV13 seems to suit my riding style perfectly. Normal riding (around town - light to light) is shifting at around 3500 and cruising at 2500-3000.
Good luck with your project!
