I recently bought a 1992 Softail Custom with 47,000 miles on it. Are there any known issues with 1992 Evos in general or Softails in particular? I assume this would be a Bottom Breather? It is un-modified in pretty much original configuration and runs great.
I have a slight leak at the transmission sprocket area. Do 1992 Five Speeds have any particular issues? Is it most likely just the seal or do these have a history of needing bushing / shaft wear and most likely need replaced?
Not really. Address the primary side leak right away. Could be a loose front pulley and if run too long, will cost you a complete transmission tear down and main drive gear replacement. That's not specific to any model Evo but the pre- late '94 are more prone to a loose pulley.
It's a bottom breather but could have top breather heads from the factory and adapter/plugs in the air cleaner mount holes of the heads. It will have bottom breather rocker covers but will accept top breather covers as well.
Not sure when OEM switched to the INA bearing, but if that is what is in there I would replace with a Koyo B-138.
Somewhere in the middle of the 92 year, other than looking at it I don't know how to tell by say the VIN or anything...
OP,
Since you are running a shovel I guess your good with a wrench and this bike will be no real trouble. The trans leak could be a few things, I think there are two seals on that shaft, main and quad, plus a little O ring that's called a 5th gear seal or something like that... Change them all if you go in there along with everything that seals the primary... Might take a good look at the belt and pullies since you are there, mine are 30 and look OK with similar mileage... Change all the fluids and go get used to it and enjoy it... You have all winter to do lifters, which will lead to a cam and the bearing ..you know.. "might as well"...
The FXSTC is my favorite bike in my 55 years of riding, I've had two -99&94- and will still have one when I'm done... They handle very well with larger/taller riders, I put a 120 on the front and a 140 on the back and it stays out of the road snakes and centerlines...
OP,
D/S
Me thinks No...there were Shovelheads with INA cam bearings!!!
Anyway..Internet Wisdom says nothing short of a Complete teardown and rebuild will suffice!!!
Me??? I ride 'em til they show me a problem...costs the same!!!
Early EVO`s came with Torrington B-138 inner cam bearings, the original B-138 is still in my `89 FLSTC.
