Idle cable carburetor spring…
Old Dec 26, 2023 | 09:36 AM
GOGOBECK's Avatar
GOGOBECK
Default Idle cable carburetor spring…
While the tank is off, I’m replacing the throttle and idle cables. I lost the idle cable spring (or there wasn’t one) that goes in the cable guide.
Needed?
Can I use a spring from a ball point pen?
Old Dec 26, 2023 | 06:00 PM
Spanners39's Avatar
Spanners39
Needed?
If you mean the return (push) cable, you don't need that cable anyway.
Old Dec 26, 2023 | 06:24 PM
t150vej's Avatar
t150vej
Needed?
True, return cable really isn't totally necessary but that aside...
If a return cable is there, that stubby spring on the carb end needs to be there to allow proper adjustment and avoid things getting tangled on the end which is possible if it's missing.
If you buy new cables, the new return will have one installed. If it doesn't, they sent you an incorrect cable. It's also possible to "spiral" the old one off and back onto the new cable.
kre84u
Jun 27, 2020 08:18 AM
The Twigster
Jun 28, 2018 11:35 AM
txfxstrider
Apr 25, 2012 05:23 PM
WG2011
Aug 15, 2011 07:58 AM
rd_king_rider
Sep 1, 2008 02:01 PM
