Clutch Adjustment Issues
Old Apr 5, 2024 | 12:26 PM
GREENOHAWK69's Avatar
GREENOHAWK69
Default Clutch Adjustment Issues
97 WG - Attempted to adjust the clutch for about an hour plus and no dice. I followed the manual and YT videos. I've done this 6+ before and it is ~ 20 minute process.
Have not done anything with the clutch or basket. I did change the primary chain, but that was prior to replacing the head gasket - which required me to put the bike in 5th gear to rotate the tire.
I did have the side cover for the transmission off to paint it. I drained the tranny fluid and rechecked the side cover and it appears to be OK - moving the clutch lever I could see inside moving.
Scratching my head in this one. Hopefully it's something easy. 😁
Old Apr 5, 2024 | 01:41 PM
Max Headflow's Avatar
Max Headflow
So the clutch worked well until you started screwing with the bike?
Old Apr 5, 2024 | 01:43 PM
RANGER73's Avatar
RANGER73
You didn't say what the problem was.
Did you reconnect the clutch cable after you reinstalled the cover?
I know you've done it before but obviously you're missing something.
Start over, loosen everything
in line adjuster, nut and clutch rod.
Turn in rod until it just touches and the allen wrench just hangs under it's own weight
Then turn it OUT 1/4-1/2 a turn, hold the rod and tighten the nut.
Take up the slack in the cable with the in line adjuster until there's a nickel's worth of slack at the perch between the cable feral and the perch,
lock the adjuster nuts. check primary and trans fluid levels.
Old Apr 5, 2024 | 02:10 PM
GREENOHAWK69
Clutch worked until I removed the transmission side cover and slapped it back on. The clutch cable needs to be attached...?
Went to do the clutch adjustment procedure and it's not adjusting correctly.
*corrected to transmission side cover from clutch
Old Apr 5, 2024 | 02:27 PM
brakeless's Avatar
brakeless
Need to be specific. Left side...derby cover where primary clutch adjustment is done. Right side...transmission cover where the cable mounts. Maybe ball and ramp issue?
Old Apr 5, 2024 | 06:29 PM
GREENOHAWK69
Rechecked the transmission side cover. Appears ok.
Performed clutch adjustment via Manual/YT, and I can't get the slack out of the clutch lever - even adjusting it the farthest it can go.
Attached Thumbnails Clutch Adjustment Issues-20240405_170153.jpg   Clutch Adjustment Issues-20240405_170111.jpg   Clutch Adjustment Issues-20240405_170146.jpg
Old Apr 5, 2024 | 06:30 PM
GREENOHAWK69
Correct.
Old Apr 5, 2024 | 06:58 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Show us a pic of the clutch release cover and the ball and ramp mechanism.
Old Apr 5, 2024 | 07:00 PM
Tommy C's Avatar
Tommy C
Check the ball ramps. They aren't in the proper orientation or the ***** fell out possibly.
Old Apr 5, 2024 | 07:17 PM
GREENOHAWK69
Picture of ball and ramp mechanism.
They were working when I had the bike on the jack and put it into 5th gear when I changed out the head gasket.
