Drakejam
Your looking at the rollers in the bearing that is pressed into the block at the opposite end of the cam nose cone bushing. That $15 bearing has given many people a major headache. It has lost a roller or two for some in the past and can cause the very issue your experiencing with the oil pump. NOT saying this is your issue, but it's worth a look.
Replace it since your there with a bearing that has "full compliment rollers", instead of the bearing that is in there now. Your current stock bearing has a plastic cage holding about half the quantity of rollers as the suggested replacement bearing. The plastic cage fails and it can drop the rollers. It was a cost saving measure by MoCo. The replacement bearing is a Koyo/Torrington B-138 bearing, has no plastic cage, and a full compliment of rollers inside. Lots of threads on bearing removal and replacement. You should check it and change it out.
I would suggest like others: (in addition to dealing with your oil pump problem) you replace the lifters, the cam bearing, and now is the perfect time to put a better cam in the bike. Your factory cam is a dog and hinders how well your engine was originally designed to run. It was an EPA thing that forced MoCo to use that cam.
Still concerned about what caused your pump to lock up. You really need to concentrate on finding the cause. I hope it's something simple. While I don't remember how many rollers are in your current cam bearing, you need to pull the cam and count the rollers inside that bearing. Someone here will know how many needle rollers are in your current cam bearing. Same with the lifter rollers, they need close inspection.
Drop the mint part bud, you are just talking yourself into thinking everything is just fine, it isn't.
