Ultima 107" motor on a 90 model Bagger
Old May 8, 2010 | 09:44 PM
  #711
Beach Boy's Avatar
Beach Boy
Does anybody know anything about swing arm bushings. Seems there are three differenf types availble. The stock liquid filled, nylon or neoprene and bearing type with spacers that press in. I had to take the trans case off and noticed the LS bushing leaking liquid. These are stock type and only two or three years old. Maybe the 120 is a little too much for the stock style bushings? Engine now has about 4000 miles. Haven't started to time or jet yet. It is rich and sounds like mor advance is in order. It still runs strong just the way it came out of the box.
Old May 10, 2010 | 10:09 AM
  #712
mesmarter's Avatar
mesmarter
Originally Posted by dts
well buttoned up the new 113 on my 91 fatty took it for a little 30 mile ride ,ran great other than back fireing now and then,but seems to have an oil leak at the oil preasure sending unit or maybe pushrod cover or tappet block this will be interesting to pinpoint!
My 107, had some backfiring, and when they Dyno'd it they found the HP, and Tque waaay down than what it was rated. So they went back and adjusted the timing. This fixed the slight backfiring and increased the hp and tqu a lot.
Old May 10, 2010 | 06:54 PM
  #713
fxr83's Avatar
fxr83
6th Gear
when i had my ultraclassic torn down for the engine swap and the trans replacement i replaced the swingarm bushings with the nylon type.i had installed these same type in my 1983 fxr and i really like them.no sway or under roll with them. i bought them fromWWW. AMERICANCLASSICMOTORS.NET They have a store on ebay.thats where I bought both sets.
Old May 10, 2010 | 06:56 PM
  #714
fxr83's Avatar
fxr83
6th Gear
how much did the dyno work cost? i need to have mine done. just want to get an idea of what it would cost.
Old May 12, 2010 | 08:45 AM
  #715
NorthGeorgiaHawg's Avatar
NorthGeorgiaHawg
BB - do yourself a favor and get a True-Track Trackula kit to replace those POS silicone-filled clevebloc H-D swingarm bushings. It has both the stabilizer the bolts to the tranny and the frame cross member; and also solid metal (not plastic) replacement swingarm bushings, new pivot rod, new rubber isolators, and a new (new style) front motor mount. The TT solid bushings don't need any spacers, either - they fill the entire space by themselves. The TT Trackula kit is not cheap, but it's worth every penny in my opinion. They give a HDF member discount if you call them. I paid $689 for my kit.
I put the Trackula kit on my bike recently, and the difference in handling is nothing short of amazing! What used to be a sloppy, floating ride is now rock-solid. My bike now tracks straight and true, and I can lean right into corners and not feel like the bike is going to lose it. Feels like a sportbike compared to before...
Old Jun 1, 2010 | 08:45 AM
  #716
paco's Avatar
paco
Hey my friends,
I am going to replace my lifters (tappets). My motor had a lot of valve train noise that was not normal for this motor. Found the front 2 tappets just about gone and the back one are on their way. about 25000 miles on the motor. Anyway, i want to replace them. what would you guys recommend as replacement tappets ? i am going to call Jerih today. Jims are wayyy out of my price. Crane are high but i may go with them or screaming eagle ? Jerih doesnt offer a big selection, crane being next after Jims. I dont know if harley even makes SE tappets.
Help me out guys .
later.......................
Old Jun 1, 2010 | 09:13 AM
  #717
grbrown's Avatar
grbrown
Thumbs up
Had mine on for over two years now and it transformed the bike. No turning back!
Old Jun 1, 2010 | 10:44 AM
  #718
Classic Beast's Avatar
Classic Beast
Originally Posted by paco
Hey my friends,
Help me out guys .
I know at one time Ultima was using Johnson lifters (they make the stock harley and stock GM lifters) but I believe some have changed over to the Andrews or Crane lifters which I understand work better. I put in the S&S lifters but still have noise so the Crane might be a better choice.
Old Jun 1, 2010 | 12:14 PM
  #719
mp's Avatar
mp
Well, I've got 50,000 miles and no complaints on my Crane lifters, with an EV13 cam and SE pushrods. But they are pricey; think they were $50 ea? six years ago. I know they only charge about $12 each for the same chevy lifters as the identical $50 Twin Cam lifters, but never found automotive lifters cross-referenced to the Evo lifters.
Old Jun 2, 2010 | 11:48 AM
  #720
Buddy WMC's Avatar
Buddy WMC
Not sure exactly what bike you have. but I installed the CCE kit in my 93 FXR. Absolutely the best money I ever spent. TV150VEJ (Rufus), followed my advice, researched and installed the CCE kit in his bike as well and is very pleased with the results. IMO, the sealed bearings are much better than nylon or Delrin. That is for you to decide, but I can tell you my bike is rock solid and runs like she's on rails at over 120mph. Been there and done that several times!!
