adjustable quickie out pushrods?
Old Dec 18, 2024 | 01:46 PM
kino44's Avatar
kino44
LOL sorry bout that I tend to do that s***t Dan
Old Dec 18, 2024 | 01:49 PM
kino44's Avatar
kino44
Originally Posted by brakeless
Well I'll give it a shot. Yes you can go another 1/2 turn without any problems on a stock motor. Did you give them enough time to fully pump up?
Yes the Lifter Blocks can wear. How many miles on the bike?
Lastly, what oil you running?
theres 61,000 now after build I take care of her gave them time to pump I have lucas 20/50 in it now usually use valvoline those blocks got some miles on them guessing around 80,000 or more
Old Dec 18, 2024 | 01:50 PM
brakeless's Avatar
brakeless
Oil should be okay. You could pull the blocks and mic them to be sure.
Old Dec 18, 2024 | 01:52 PM
kino44's Avatar
kino44
Lifter blocks are a possibility, what cam went back in? What kinda miles since the lifters got replaced?
the stock evo cam green DOT on cam is all I know think it was the V grind 84 cam lifters got replaced twice now bike has 61,000
Old Dec 18, 2024 | 01:56 PM
kino44's Avatar
kino44
Thanks guys will try the half turn before I brake into her
Old Dec 18, 2024 | 02:07 PM
t150vej's Avatar
t150vej
Anytime you mess mess with the valve train they're subject to be noisy and especially with adjustables. Unless it's clacking, just run it.
Stressing over it just makes it tick louder.
Old Dec 18, 2024 | 04:45 PM
kino44's Avatar
kino44
Originally Posted by t150vej
Anytime you mess mess with the valve train they're subject to be noisy and especially with adjustable. Unless it's clacking, just run it.
LOL I wear earbuds
Old Dec 18, 2024 | 11:47 PM
Kristeff's Avatar
Kristeff
Stage IV
I did not see anyone suggest to check your lifter filter screen. Often forgot about and good practice is for it to be checked every other service I believe.
Old Dec 19, 2024 | 01:54 AM
TwiZted Biker's Avatar
TwiZted Biker
Before you tear into or buy anything find some straight 50wt and do an oil change, pay attention to any differences in sounds or feel of the bike in general. This can tell you a number of things about the engine's condition overall. That kind of mileage the whole valve train is worn from the lifters & blocks to the rocker arm bushings. Quiets down some with the heavy oil it confirms the wear is real.
Old Dec 19, 2024 | 07:07 AM
kino44's Avatar
kino44
done, I do that often
