My journey begins...
Old Mar 25, 2025 | 05:11 AM
  #41
IBDAGRIZ's Avatar
IBDAGRIZ
Originally Posted by rockjock729
Just cleaning the jugs and top covers. The front jug when through an ultrasonic cleaning with wire brush cleaning after. The back jug has not had any cleaning done to it yet.
more cleaning is needed after ultrsonic cleaning.
Wirebrush applied.
Wire
Don't forget to oil the bore back up. Replacing the lifters while you're in there is a good idea actually. Larry's lifters are Johnson hylifts and you'll be happy with them.
Griz
Old Mar 25, 2025 | 09:56 AM
  #42
rockjock729's Avatar
rockjock729
Just spoke with Joe and Johnsons does not make lifters for the Evolution, I have torn the engine down to stopping at cracking the crank case. The piston rods have no vertical play in the bearings, so I will leave it at that.
Using an EV27 cam with the lifters from Fueling Parts, can I use my original pushrods(cheaper) or the HP+ One Piece pushrod?
Old Mar 25, 2025 | 02:34 PM
  #43
IBDAGRIZ's Avatar
IBDAGRIZ
Not sure who Joe is, but he doesn't know what he is talking about concerning Johnson lifters.
Not sure about Fueling lifters these days as there are lots of cheap knockoffs.
Griz
Old Mar 25, 2025 | 03:21 PM
  #44
98hotrodfatboy's Avatar
98hotrodfatboy
Just a clear couple things up, there's Johnson lifters and then there's Hy-lift Johnson which are made by topline and distributed by Larry's motorcycle machine.
http://www.larrysmotorcyclemachine.com/lifters.html
Also I'm like 95% sure that all of Fuelings lifters are USA made..
I use the limited travel lifters in my Evo and they work very well..
Old Mar 25, 2025 | 03:48 PM
  #45
rockjock729
Joe is the fellow with whom I spoke with at Johnsons, not Hylift Johnsons.
Old Mar 25, 2025 | 03:54 PM
  #46
rockjock729
"I use the limited travel lifters in my Evo and they work very well.”
Limited travel lifters? From Fuelings?
Old Mar 25, 2025 | 05:14 PM
  #47
98hotrodfatboy
Yeah I could have sworn I bought a set of limited travel lifters from fueling for my Evo.. I did call them and ask and the guy that I spoke to, who's only been there 4 years so he didn't know anything about it and they currently do not sell them for Evo's.. This was probably 8-10 years ago.. My memory is getting worse every year..
Old Mar 25, 2025 | 09:18 PM
  #48
rockjock729
You can purchase lifters from Larry’s with travel limiters. That may be what you are referring to with “limited travel lifters".
Old Mar 25, 2025 | 10:34 PM
  #49
98hotrodfatboy
Correction.. S&S HL2t in the Evo and Fueling limited travel race in the TC.
Old Mar 25, 2025 | 10:36 PM
  #50
98hotrodfatboy
Yes I know. He has the 2013 sl..
