Easy clutch?
Old Jul 15, 2025 | 06:44 PM
bentparts's Avatar
bentparts
I have the original White Bros. EZ clutch arm attachment in my FLHS, since 95. I made a spacer to take up the extra cable slack that fits at the lever and got rid of the spacer they gave you that mounted at the trans cover. It didn't allow enough thread engagement for the cable IMO. Really does reduce effort. Combine that with a new well lubed cable and it's buttery smooth.
Old Jul 15, 2025 | 07:47 PM
Sportfisher23's Avatar
Sportfisher23
I agonized over all this. I just got new OEM items and a Barnett Cable for my 89 FLHS. I just want to get moving again!
Old Jul 15, 2025 | 10:50 PM
mdkelley's Avatar
mdkelley
I installed a new cable (teflon lined I believe, no lubing) on my 93 and the clutch seems really easy now to me. No idea what the ramp degree is in the stock arm. It had a pretty stiff pull prior, cable was old and not sure if it was routed in a way to minimize any tight bends.
Old Jul 16, 2025 | 08:17 PM
SparkyD's Avatar
SparkyD
Ordered the Muller Power Clutch yesterday, picked up 10mm stainless steel hardened bearings on the way home today. All the gaskets I need for my transmission. Figured since I'm going in I might as well be prepared
Old Jul 22, 2025 | 01:32 PM
Rains2much's Avatar
Rains2much
Originally Posted by Yankee Dog
I think 98hotrodfatboy did some experimenting with changing the size of the ***** to get more clutch movement. Don't remember the details, and not sure if it changed hand effort.
See post #17 for video
https://www.hdforums.com/forum/prima...g-neutral.html
Original thread:
https://www.hdforums.com/forum/evo/1...vo-clutch.html
It’s a cool trick and works… however what it does is increase how far the lever can move the clutch to open.. like when you want more play for an extra plate in your clutch pack. It really doesn’t change the force required by your hand.
Old Jul 28, 2025 | 04:26 AM
mplecha's Avatar
mplecha
I went with a mueller after I broke
my hand. It helped. No issues adjusting it.
Old Jul 28, 2025 | 04:52 AM
Greaser1340's Avatar
Greaser1340
I bought the single item part which was just the base that the ***** sit in with larger ramps. Because I run a kicker, the space inside the kicker housing is quite limited and the extended clutch pull arm hits against the inside of the cover, restricting the movement. The larger ramps made it a massive pain to try and adjust the cable correctly and despite collapsing and resetting the whole apparatus over a dozen times, I could never get it to work correctly (I also run a BDL ball bearing clutch / primary) so went back to the stock unit.
Im still using the oem clutch cable from 1995 which has seen better days so will likely replace that this winter with a new one and hopefully see some improvement.
Old Sep 7, 2025 | 10:48 AM
SparkyD's Avatar
SparkyD
Finally installed the Mueller Power Clutch ramp assembly and new clutch cable. Wow! I did NOT expect that much of a difference. The pull is a lot easier. What surprised me more is it feels like the friction zone is a lot narrower, not sure why that is.
Anyway, I'm very satisfied with this investment. Thanks for the recommendation guys.
Mincemeat90
May 17, 2024 08:56 AM
BadDogBiker
Nov 2, 2022 03:56 AM
Streetglide2371
Jul 5, 2017 02:38 PM
Gibler77
Mar 8, 2015 02:02 PM
boduke883
Jun 12, 2011 11:58 PM
