Inlet manifold air leak
Old Dec 2, 2025 | 09:01 AM
Racepres's Avatar
Racepres
Since the old O-ring or Rubberband days.. I have learned to Not Overtighten anything on the intake.. Worse with the Early Evo Compliance fittings...But..Gorilla Tight is Not necessary, nor desired on the late Evo Manifold either...
Old Dec 2, 2025 | 11:42 AM
t150vej's Avatar
t150vej
I wouldn't use any sealer. Only grease. What rubber are you using? If anything find a new stock one.. SnS is not anything special.
This is a stock motor with stock intake manifold?
Muskrat went thru all this last year (?) where he had the large S&S manifold-to-CV adapter and was trying to use James flange gaskets. Took us a while on that one.
I stopped using grease, realizing it's such high temp rated it never drys out and can let the (my) manifold wiggle. If it can wiggle up down, it can move forward or rearward and that is a leak if not centered between heads.
S&S flanges are $85. and HD are $35. Any other brand is total junk. You have less that 60/40 chance it will seal.
Old Dec 2, 2025 | 01:03 PM
Max Headflow's Avatar
Max Headflow
It don't take much grease. The AC mount should hold it in place. The stuff I use dries out pretty quick.
The important stuff is making sure that the manifold fits the heads. There can be too much or too little space between the manifold and the heads. Things like bore kits, strokers can change the length of the cylinders. SnS 113 motors use shorter manifolds than stock evos. It's good to install the manifold to the heads without the rubbers and see how much slop there is..
Also one of the worse rubbers is the Jame silicon ones. They'll ooze between the heads and manifold plus squeeze out any crack.
Old Dec 2, 2025 | 01:16 PM
t150vej's Avatar
t150vej
You're talking big, modified engines. I'm on stock engines.
I agree on the James blue. They will seal - one time. Then your flanges are warped and must be replaced.
Old Dec 2, 2025 | 01:33 PM
Muskrat21's Avatar
Muskrat21
G'day Fellas.
Thanks for the replies.
It's a bog stock 1999 80" EVO. It's getting hard to get genuine HD EVO parts down here and if I can find them $$$$$.
When snugging up the flanges there would only be about 1mm of compression on the rubbers.
I'll pull it apart again this morning and check how much side play the manifold has. I'll try to find some genuine flanges & rubbers (it's a 3 hour ride to the nearest shop).
Cheers
Old Dec 3, 2025 | 01:26 PM
Muskrat21's Avatar
Muskrat21
G'day Fellas.
I think I've got it. Put it together with just the slightest bit of WD on the rubber only. I use a spirit level to get the motor vertical and do the same for the manifold. Manifold bolted on till the rubbers just touched, mounted the carb to the bracket and snugged the manifold bolts. Threw the rest back on (bar the tanks), hooked up the aux tank and tested it. 99.9% fixed. That was the last pair of rubbers I have.
The only other thing I did was look up the jetting for my bike. Mine is 45/185 plus a 0.5mm shim under the needle. So I put one under it's needle. Took it for a test hill run. Sooooo much better and made 140kph at the top.
Mate is coming to take it home today.
Thanks for all your input.
Cheers
Old Dec 3, 2025 | 03:18 PM
98hotrodfatboy's Avatar
98hotrodfatboy
I always use a silicon grease as in caliper slider bolts silicon.. It can take the heat pretty good and when the cylinders expand the gap at the Intake will increase.. If your flanges are bent from torquing on over sized seals you can always pound them out again, I have without issue.. Not necessary to purchase new flanges.. OEM seals are the go to if possible...
Old Dec 3, 2025 | 06:01 PM
3thes2's Avatar
3thes2
Stage III
Originally Posted by Muskrat21
G'day Fellas.
I'm helping a mate with his 1999 EVO Fatboy with only 18,000Km on it. I found it had an air leak. Many years ago a "shop" had installed a set of pipes and K&N air filter and jetted the carb with 48/200 jets. I suspect to mask the air leak. I thought I'd tackle the air leak before doing the jets.
Well haven't I had "fun". Had the manifold on & off at least 10 times! After the first few times (with new rubbers) I had a good look at the flanges and found them to be slightly bent. I ordered new flanges and more rubbers. I've watched all the youtube videos and tried everything putting it together (dry, with oil, grease, hylomar, even silastic) to no avail. The leak is definitely at the flanges, not the carb or voes or vac line to fuel tap.
Question: with the flanges bolted up hard should I still be able to twist the manifold?
Any suggestions.
Cheers
The flanges are bolted up properly, you definitely shouldn’t be able to twist the manifold any movement means the sealing surfaces aren’t seating. Double check the manifold alignment by dry fitting it without rubbers, make sure the spigots aren’t out of round, and use good-quality (preferably OEM) rubbers. A light smear of silicone grease is fine, but if you need sealant to stop a leak, something isn’t flat or aligned. With fresh, flat flanges and proper fitment, the manifold should lock solid with zero twist. Cheers.
Old Dec 3, 2025 | 06:18 PM
Max Headflow
You can twist them if they are greased. Done it a number of times I've messed with different length manifolds a bunch. Last one was cutting down a manifold from a SnS 116 ci motor to make a standard length all bore 107.
https://www.hdforums.com/forum/engin...l#post20483984
Old Dec 3, 2025 | 06:48 PM
98hotrodfatboy
That was a great thread Max.. I don't have the shop or the tools that you have but I can fit an intake to heads that have been shaved/milled or whatever by hand with a file.. Takes time and a lot of mounting and in mounting but I've gotten pretty good at it.
Necessity is the mother of invention...
cuda67bnl
Exhaust System Topics
Apr 20, 2022 07:32 AM
80Glide
Shovelhead
Jun 12, 2021 02:08 PM
Moondogger
Jul 8, 2012 10:11 AM
Gaffney31
Dec 31, 2011 10:43 AM
msoucy
Aug 9, 2005 02:32 AM
