engine clean?
Old Mar 4, 2008 | 10:09 PM
wrknman's Avatar
wrknman
Default engine clean?
I just got a rebuild and as part of that the shop bead blasted my engine. Well, it looks great and I want to keep it that way. Mines a 91 and not powdercoated. What can I do to prevent tarnishing it?
Old Mar 5, 2008 | 04:07 AM
megawatt's Avatar
megawatt
Default RE: engine clean?
wrknman,
I like the look of bead blasted aluminum. I also don't mind if it gets a bit dirty and/or gets some corrosion on it (it just wipes off). The only thing I can think of to protect the freshly bead blasted look would be to have it powdercoated with a clear finish. Maybe there is a semigloss or flat clear powdercoat finish available if ya don't want it shiny.
Or there is always clear engine paint...
Old Mar 5, 2008 | 06:58 PM
wrknman's Avatar
wrknman
clear engine paint?....I didn't know anything about that. I'll look into that. It looks awesome now.
Old Mar 6, 2008 | 03:51 AM
uawman's Avatar
uawman
powdercoating retains engine heat. Unless it's a showbike I'd stay away from the painted and polished cases.
Old Mar 10, 2008 | 08:53 PM
89 FXRS's Avatar
89 FXRS
UAW states: powdercoating retains engine heat. Unless it's a showbike I'd stay away from the painted and polished cases.
That is the most wild thing I think I have read. Do not paint or powdercoat the cases? Due to heat??? Unless it is a showbike??? The cases you say??? I guess that the jugs and heads are ok to powdercoat then?
Ok I give up, where did you come up with that idea?
Old Mar 11, 2008 | 04:40 PM
notlost_nc's Avatar
notlost_nc
I like to use Simple Green on the '84, it's the non-painted version.
Old Mar 11, 2008 | 09:03 PM
jbhoyle's Avatar
jbhoyle
HD has a spray engine paint that make the jugs and heads look new. It's a little exspensive, but I painted my a year ago when I rebuilt the top end (app. 10k miles) and they still look new. I just was the engine with Bikebrite or S100 and it looks like new. If I can find the can I'll give you the P/N.
Old Mar 12, 2008 | 07:47 PM
riden2low's Avatar
riden2low
ORIGINAL: notlost_nc
Same here......Simple Green....Just spray it on and let it sit and wash off.......do the same to the engine in my truck.
Scottyxbones
Powdercoat & Paint
Jan 9, 2019 04:02 PM
MysticPurple
General Topics/Tech Tips
Aug 24, 2017 08:02 AM
broziff
Detailing
14
Apr 5, 2017 12:32 PM
RodeoHard
Oct 29, 2012 11:53 AM
dlongo8241
Mar 5, 2006 09:00 AM
