I'm trying to figure out how to remove the the top part of the ignition switch (the chrome **** where the key fits) on my 1985 FLTC. I have the service manual but its not very clear...or maybe its just me? If anyone can help that would be greatly appreciated.
Take the entire dash off, unplug all the wires and set it aside. Remove the large nut that holds the tamper shield. It's a large, fairly thick metal plate that has tabs extending off it that covers the lock lever and has a warning sticker on it. Then you'll have better access to the fork lock mechanism which is the phillips head screw with a spring and lever. (The book shows that picture) Push the lever back and work the screw out of the slot.... and I can't remember what happens next. I had all mine off 3 months ago, but can't remember each step exactly - sorry.
The mentioned "pin" that you pull to release the **** is either on the left or near center (probably left). It's up under the lip of the housing that the dash screws to, and it's hard to see without a flashlight. Remember to push down on the **** before pulling the lock pin. When it all comes apart, you'll see it's fairley simple. And if you're trying to get the actual electrical switch out, there is a nut (like a radio antenna nut) on top off the switch stem. Takes a special socket for it, butI used channel-locks because you'll never see it anyway and it'll come off easy soon as it's broken loose. Then take the 4 bolts out on the sides of the shroud and pick it up to pull the wire plug off.
There is a flat metal tab, which you should be able to see when you remove the gauge assembly (as you mentioned it is an FLT). Pull the tab and the lock comes right off.
