Can someone help with `94 Fatboy ignition switch wiring!
Old Apr 27, 2009 | 04:14 PM
staged67gspwr's Avatar
staged67gspwr
Exclamation Can someone help with `94 Fatboy ignition switch wiring!
Hi,im in the process of ordering a `94 service manual,i just got the bike and i need a picture of how the ignition switch at the dash is wired up,please email me a picture or diagram at staged67gspwr@aol.com
Thanks
Old Apr 27, 2009 | 06:46 PM
t150vej's Avatar
t150vej
On the way, and you are quite welcome.
Old Oct 9, 2019 | 09:21 PM
Tonyb65's Avatar
Tonyb65
I have an 86-99 softail manual however it does not go into detail about the ignition switch and which wires go where. The switch I ordered did not come with any installation instructions. I am doing a tank swap on my 95 XLH 883 DLX sportster and putting on a split tank from a 1994 FLSTF Fat boy. see photos below. any help would be appreciated and wire sizes would be helpful also i.e 18 gauge or what have you.
Split tank 94 Fat boy on sportster
pre fabrication test fit onto 95 XLH 883 Sportster(Fatster project)
have no wire installation instruction. Need wire gauge sizes and which wires goes where.
I still have to remove OEM ignition and run wires to dash switch.
Old Oct 9, 2019 | 10:29 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Look at the wiring diagram at the back of your service manual.
That should tell you where all the wires go.
Old Oct 9, 2019 | 10:39 PM
Tonyb65's Avatar
Tonyb65
Thanks THC I'll take a look there.
Old Oct 10, 2019 | 06:29 AM
misfitJason's Avatar
misfitJason
Size:  31.0 KBCan someone help with `94 Fatboy ignition switch wiring!-photo595.jpg
Old Oct 10, 2019 | 08:01 PM
Tonyb65's Avatar
Tonyb65
Thank you Jason that will be a lot of help. would you know what gauge wire is used for the 2 jumpers(1 yellow and 1 Tan) look like 14 gauge but i'm not sure
Old Oct 10, 2019 | 08:42 PM
misfitJason
It's shouldn't matter that much. 14-16 gauge should do the trick for those tiny connections
Brenschu
Sep 17, 2017 08:10 PM
claimjumper2013
Jun 25, 2017 10:37 AM
1962300
Flathead
Mar 7, 2013 07:24 AM
781/2fxs
May 13, 2009 11:24 PM
bigkahuna327
May 27, 2008 11:15 AM
