Worthwhile to add a a FI controller to a stock '98?
Old Aug 9, 2009 | 09:32 PM
Jahillsr's Avatar
Jahillsr
Default Worthwhile to add a a FI controller to a stock '98?
I have a stock '98 RKC and was wondering if others who had switched to a Power Commander or other unit, feel it made a difference for them.
TIA, <Jim
Old Aug 11, 2009 | 10:39 AM
Red98RoadKing's Avatar
Red98RoadKing
I put an older Power commander on mine and I like what its done for it. No more rejetting just plug another fuel map in and presto.You don't even get the old paws dirty...
Old Aug 11, 2009 | 10:49 AM
Beemervet's Avatar
Beemervet
Absolutely. Your bike will run cooler and have better throttle response. And if you do anything, such as pipes and air cleaner, you can dial it in easily. I have a PC II available. I only upgraded to the PC III so my tuner could dial in my extensive mods.
Old Aug 11, 2009 | 10:29 PM
LeadDoggy's Avatar
LeadDoggy
If it's all stock, don't
It you have installed pipes and open air cleaner, then do it!
Just installed one on my 98 Classic but only because i just replaced my cam bearing and one thing lead to another. Cam, lifters, pushrods, PCIII USB, V&H true dual head pipes and a dyno tune. Should have done it years ago....
Old Aug 17, 2009 | 12:11 PM
upright's Avatar
upright
I also have a '98 RK Classic with injection, still all factory configuration. I've also wondered about adding a PC. Are they plug-and-play, or would it need to be dyno'ed?
kalamitty
Apr 13, 2012 12:42 AM
magnum629c
Feb 8, 2012 06:40 PM
IronAK
Mar 6, 2011 06:36 AM
Redbob 07
Apr 10, 2009 10:29 AM
Born2cure
Apr 28, 2008 07:16 PM
