Ignition Switch Removal
Old Mar 22, 2010 | 03:23 PM
Leftcoaster's Avatar
Leftcoaster
Default Ignition Switch Removal
Got a '95 FLHTC and am getting ready to change the fork oil. First time I've done this myself on the old girl. I've read the Service Manual and it seems straight forward enough. Any tips on ignition switch removal? or on this task in general?
Thanks
Old Mar 22, 2010 | 04:27 PM
95 Ultra's Avatar
95 Ultra
I just installed a new ignition switch on mine. To remove it, turn the switch to the accessories position, then turn the key counterclockwise, then place the blade of a small screwdriver against the small tab that is located under the switch. Depress the tab with the screwdriver and the switch will lift right out. Just don't force anything.
Old Mar 22, 2010 | 05:15 PM
t150vej's Avatar
t150vej
Uh... You don't have to do any of that if you have air ride... fork oil change is a 15 minute job unless you do it by the book, then it's near half a day...
Old Mar 22, 2010 | 05:18 PM
the_ogre25's Avatar
the_ogre25
How long to do the seals? 88 flhs with a 95 fairing.
Old Mar 22, 2010 | 05:28 PM
t150vej's Avatar
t150vej
It depends on you're fixed for working conditions, how handy you are with your tools and how quick you are... I reckon. I'm getting old and slow myself Assuming you're referring to the oil seals, it's about half the time it'd take to get the front wheel and fender off, or less. But as most of us know, when stuff gets old, sometimes you run into things that really "eat your lunch" like corroded bolts, rusty lock rings, broken lockwashers and the list goes on...
Old Mar 22, 2010 | 06:42 PM
sqdealgeorge's Avatar
sqdealgeorge
T150vej is correct el mundo ! Guys would bring there baggers to the shop for the fork oil change and expect a big $ figure say 4 hrs + beer ! They would come back and Good God only 1 hour labor and fork oil + beer Bike front up /open drain plugs let the old fork oil out /remove the guts from the air valve (the end of the left handlebar grip ) Use a vacuum set up and suck the proper amount of fork oil say 8 oz up the individual fork tube This is getting confussing call me at 608 847 4240 Rufus should have told you how how to do this !!
Old Mar 22, 2010 | 11:05 PM
BB4xl's Avatar
BB4xl
A cheap Vacum pump will work fine. I have one I picked up a Harbor Frieght. It came with a bunch of plastic fittings and some hose that worked great. I use one of these http://www.sears.com/shc/s/p_10153_12605_00947641000P for the crush washers on the drain screws. It works so well you will be shocked.
Old Mar 23, 2010 | 09:30 AM
Leftcoaster
Thanks guys. After I posted I got to thinking about the air assist and the vacuum pump I use for bleeding brakes. Using it to pull the fork oil back up into the forks was going to be my next question. Glad to hear I was actually on track with my thinking (sometimes I scare myself).
Thanks again for all the help. I'll have it done in about 30 minutes.
BTW: I'm going to drill the caps on my '06 and use the same method on them.
bearammus
Mar 6, 2014 08:08 PM
Badbagger
Mar 21, 2010 07:51 PM
toad6301
Dec 21, 2009 04:47 AM
FunkyNova66
Sep 26, 2009 07:32 AM
rustyrun
Sep 3, 2007 06:30 PM
