EVO bagger radio input...
I have tried several car speakers on my 1990 FLHTCU and my favorite so far is the 4" Infinity Kappa which have high sensitivity, 93 db . Higher sensitivity is better for me because it does not take as much power to deliver good volume. The 4' Kappa is actually a 2 ohm speaker but uses a hook up wire to give a 4 ohm load. I am using the Biketronics Retro Radio kit with a Sony head unit that is designed to handle 2 ohm as well as 4 ohm speakers.
I read the 1996 also uses 4" but can be adapted to use the 5 1/4 speakers. One fellow wrote the the inner fairing is the same from 96-2001 so it is just a different spacer used for the 4" speaker they used in 96-97. A couple fellows posted they were able to remove the adapters from the original speakers and cut the centers out and use them as a spacer or one suggested buying a new spacer for a '98. At any rate, you may want to take a look at it, if you can go to a 5 1/4 " speaker you will have more choices.
I can't say too much about quality on various speakers , I don't even attempt to compare a sound system on our old Harley to a home theater, or a new Harley/metric . The key thing I look for is volume without any undesirable sounds or distortion.
http://signature.crutchfield.com/S-x...ssi=0&tp=27794
