Difference between a current softail and an Evo one
Old Jun 28, 2017 | 10:44 AM
  #31
shepa401's Avatar
shepa401
Originally Posted by staged67gspwr
Does anyone know if 2000-up fatboy front fork sliders fit on 99-down fatboy,i wanna upgrade to newer caliper
Yes, I just put sliders from an 03 on my 94.
I think the early 2000-06 wheels with 3/4 axle are the same no?
From what I found softails did not make the change to the larger axles until 2007. Somebody please correct me if I am wrong.
Yes all i want to change is the fork sliders so i can use the newer brake caliper up front
I used sliders from a 2003 Fatboy and a take off 4 piston brake caliper from a 2005 Road King. Everything bolted up and had no issues using the rotor and wheel set up from the evo. It is when you upgrade to the Brembo calipers that you need to get the larger diameter rotors.
Hope this helps clear some things up for you.
clipse
Jun 2, 2013 04:22 AM
pauliespringer89
EVO
Nov 25, 2011 09:28 AM
quist
Feb 8, 2011 10:32 AM
richardhead84@yahoo.com
Dec 13, 2010 12:05 AM
deezel11
Oct 16, 2010 05:22 AM
