Timing a stroked Evo
Old Jun 6, 2011 | 03:44 PM
Spanners39's Avatar
Spanners39
Default Timing a stroked Evo
I have a Trike in my workshop with a 91 Evo motor with Edelbrock heads and an Axtell 1480 stroker kit.
Anyone know the correct ign timing data? Its eaten the pistons, knocked big lumps off the ring lands and I am thinking this was a timing issue.
As the pistons travel further per degree of rotation I am thinking I will dial gauge the timing and re mark the crankshaft........unless any of you know different?
Old Jun 6, 2011 | 04:58 PM
grbrown's Avatar
grbrown
I had a JIMS stroker kit in my Glide during an earlier life, but I really don't recall what the correct timing is. However you could email Axtell and ask their advice?
Old Jun 6, 2011 | 07:21 PM
1997bagger's Avatar
1997bagger
Need to do some checking, Axtell doesn't offer cranks and kits are big bore with a 4 5/8's stroker being 107" and most likely an S&S is used. They offered the odd cubed Nikasil cylinder but big cubes with a 4 5/8's crank
Attached S&S crank identifying info and timing recommendations
http://www.sscycle.com/instructions/...t.php?x_cat=26
Old Jun 6, 2011 | 08:48 PM
Spanners39's Avatar
Spanners39
Says Axtell on the jugs and is std bore but with a huge stroke...must be a different crank in there then.
Old Jun 6, 2011 | 09:04 PM
1997bagger's Avatar
1997bagger
If it is a stock bore then someone stuffed a 4 3/4 crank in there, very possible setup for torque with the trike setup, only chance is to view numbers through the timing hole.
Measure the piston travel and will give you stroke length, sounds like someone did some clearancing to stuff the crank in a stock case. Good Luck!
Old Jun 7, 2011 | 12:40 AM
Spanners39's Avatar
Spanners39
There are cutaways on the inlet side of the piston skirts, not really looked at the cases but from my research (which was a result of replies in this thread) the stroker cranks have timing marks on them.....but you are supposed to play about with the timing and run them at 30-32 degrees rather than 35.
Old Jun 7, 2011 | 01:33 AM
grbrown's Avatar
grbrown
It is true Axtell do not currently offer stroker kits for Evos, but they do for shovels, so may have done once for Evos. They do offer cylinder/piston sets for stroker Evos. As I stated previously I had a JIMS stroker crank in my motor (that was what my builder supplied and installed), so that is another possibility. An email to Axtell doesn't cost much, if there is a possibility it will help! Alternatively look into JIMS to see if they can supply answers.
Old Jun 7, 2011 | 04:34 AM
Spanners39's Avatar
Spanners39
Axtell site was very useful, as was the link in a previous post...I have the answers I seek now.....thats why I am a member of this excellent forum :-)
Did you ever complete that 6 gallon tank conversion?
Old Jun 7, 2011 | 04:55 AM
grbrown's Avatar
grbrown
Thumbs up
Great stuff and glad we helped.
As for that tank it is like a stone round my neck! I'm close, fiddling about trying to get enough clearance for the top stabilizer. More news in my tank thread before too long!
Chopper Nate
Engine Mechanical Topics
Apr 30, 2019 08:45 AM
Pimp Daddy
Exhaust System Topics
22
Sep 18, 2012 10:54 AM
APOCALYPSE
Aug 18, 2008 03:34 PM
chopper_53e
Feb 11, 2008 05:00 PM
TxMoores
Feb 28, 2005 12:34 AM
