"popping" sound from front sprocket
Old Jul 9, 2011 | 05:41 PM
mjmangus's Avatar
mjmangus
Default "popping" sound from front sprocket
My son has a 94 fxstc. We have it on the lift with the back wheel raised and when we turn the wheel there is a popping sound coming from the area of the front sprocket. It's kinda subtle but there. As you rotate the rear wheel it makes a pop-pop sound, twice per one complete revolution. Any ideas?
Old Jul 10, 2011 | 02:40 PM
mjmangus's Avatar
mjmangus
any idea at all?
Old Jul 10, 2011 | 03:15 PM
Spanners39's Avatar
Spanners39
Stone embedded in the belt? Tight Spot?
Spanners39's Avatar
Spanners39
Or even a duff wheel bearing?
Old Jul 10, 2011 | 03:31 PM
Bama91's Avatar
Bama91
Chain not straight, bad tooth, bent sprocket?
Old Jul 10, 2011 | 03:36 PM
jsbridgew's Avatar
jsbridgew
you gotta just open up that primary and see what's what.... that's the only way you're really gonna be able to figure it out
Old Jul 11, 2011 | 07:20 AM
mjmangus's Avatar
mjmangus
The belt is new and there is no debris. A closer look at the front gear looks like it had a narrower belt at one time. About 1/4 inch of the gear has no wear. Since this is a new belt, is it possible for the teeth of the belt to be hanging on to the sprocket then popping out? Thanks for any and all replies.
Old Jul 11, 2011 | 09:39 AM
jsbridgew's Avatar
jsbridgew
stock 94 FXST should be a 1 1/2 inch belt.... if there was ever a narrower belt on it, it would have been a 1 1/8 ....rear pulley would had to have been changed to accommodate the belt width ....pitches for both belts are the same, so skipping teeth is unlikely unless the belt is shamelessly loose
sounds like you're back at stock, though
open the primary and find out what's going on..... it's easy enough to check
agove
EVO
22
Feb 11, 2014 11:07 PM
omgtkk
EVO
11
Jul 4, 2012 06:26 PM
PauleyB
Jun 18, 2011 12:12 PM
Springer97
Jun 3, 2008 11:59 AM
Johneb48
May 11, 2008 04:03 PM
