Rocker Box advice
Old Dec 24, 2011 | 12:48 AM
PatZ4's Avatar
PatZ4
4th Gear
Default Leaky Rocker Covers
I have the same issue with my 87 FXLR, and also want to do it myself. Are the back bolts as difficult to get at on my bike?
PatZ4
Old Dec 24, 2011 | 12:52 AM
PatZ4's Avatar
PatZ4
4th Gear
I have the same issue with the rockers on my 87 FXLR. Are the back bolts difficult on my bike also?
Old Dec 24, 2011 | 06:08 AM
miacycles's Avatar
miacycles
On some bikes the left rear can be a problem, just drill the frame over it. You will need to start out with a smaller bit and end up with about a 3/8" bit. Hope this helps.
Old Dec 24, 2011 | 11:22 AM
im's Avatar
im
Originally Posted by woody0404
It's the offseason here in Ohio and my 95 EG has developed a leak on the front rocker box bottom gasket closest to jug. My locally owned HD mechanic will change out all rocker box gaskets as well as pushrod tube o rings on both jugs as well as rejet carbs and change oil for $250. My question is...how hard is this to do myself? I'm pretty mechnically inclined, have the manual and see that a set of Evo gaskets are under $50. Just checking to see if there will be some hiccups I may encounter by doing it myself versus a professional. Any feedback is appreciated...
That seems like a very fair price since at minimum you are looking at about $75 in parts with gaskets, oil change and filter. Why rejet the carb? I am guessing you have all the simple hand tools available along with a bike jack or something that will hold the bike straight-up and rear wheel off ground. The job would take about 4 hours if you have never done it before...If you have the 3 piece rocker covers and if things are not lined up properly the gaskets will leak when installed and you get to do the job again but the second time it will be faster. The rate limiting step is the difficult to access top rocker bolt..some people used cut allen wrenches and other drill frames or purchase the special tool..$250 is a very good price for all that work but if you have plenty of time the experience gained might be worth it.
Old Dec 24, 2011 | 12:13 PM
woody0404's Avatar
woody0404
Thanks all...I'm going to tackle it myself after New Years. I'll let you know how it goes. thx for all the input.
MxNut
Jun 22, 2019 09:35 PM
MURPHCC1
Exhaust System Topics
Aug 31, 2013 09:29 PM
2006FLST
EVO
14
Apr 5, 2011 12:11 PM
ink.slinger
Shovelhead
May 8, 2008 04:18 PM
winpitt
Sep 27, 2006 07:51 PM
