starter kickback
Old Mar 16, 2012 | 09:42 AM
  #31
miacycles's Avatar
miacycles
The adjuster on the cable is up by the handlebars. It may be hidden under a rubber sleeve.
Old Mar 16, 2012 | 04:18 PM
  #32
RidemyEVO's Avatar
RidemyEVO
I'm blind as a bat, found the adjuster. Checked the carb cable play and there may have been a bit more the carb could open up so I adjusted the cable so when the throttle was turned and I pushed on the carb round thing the cable rides on it wouldn't go any more and of course that messed up the idle so I cut that back to the point I had to loosen off the cable a bit more. So I got that sorted out and reset the ignition and set it to stage 2 ( maybe I shouldn't have done that at same time as the carb). So I hit the road and and it seems much better, I got it upto 150km or 93 mph and if I didn't have to slow down for the *** end of the truck in front of me it may have done better. So kudos to you John.
Thanks
Old Mar 16, 2012 | 08:28 PM
  #33
miacycles's Avatar
miacycles
Glad it all worked out. We see this all the time, especially after someone changes grips etc.
rol427
EVO
20
Sep 12, 2018 03:31 PM
fathog
Jan 27, 2013 09:28 PM
billyfish
EVO
May 17, 2012 09:37 AM
Jackie Paper
Dec 10, 2011 11:27 AM
cathead
Aug 11, 2011 04:54 PM
