Stripped allen heads $#%@&%
I get home tonight and shut off the bike. 1/2 hour later, go out to start the bike (taking my little girl to a volley ball game), and it backfired once and that's it. Wouldn't start. Pull plugs, they look good, got good fire. Pull the air cleaner to remove the gas line and blow back through it and find rounded allen head bolts. I was able to get 2 of them off, but the other one is stuck. I was able to get to the gas line and blow through it and got the bike started once I got everything put back together. BUT......
I think my problem is a vacuum leak. Lets refer to the photo.
This is supposed to be my setup. Although my filter looks like the one in the lower photo.
Bolt number "5" which holds the whole thing to the motor, pulled through the back plate and will not keep it tight. Actually it's a steel insert that pulled through and will not hold now. I believe this is causing a vacuum leak between the carb and the intake. Sohave another back plate off of a 94 Fatboy, which will have to have a fitting installed to be able to use my crankcase vent tube with it. No big deal. But I can't get the other allen bolt out (number "6" in the photo). It's got a smooth round head, so I can't get a pair of ViceGrips on it either like a cap screw.
So any ideas as to how to get the sucker out?
2.) use toothpaste or valve lapping compound ( grit) on the end of your tool
3.) use a dremel to cut a slot for a screwdriver in the head
4.) get left handed drill bits from the snap on truck to drill out
the 94 is for a "head breather" and may not mate up easily at the heads.
what about you get a hi flow air cleaner kit, either screaming eagle or ness ?
------- blow through gas line ?
like fuel line?
if you think your have a vapor lock problem, think about checking the fuel line routing, and make sure the fuel cap is vented.
---and you could alway blow into the gas tank to push fuel into the float bowl
intake leak, yeah probably if the carb isn't mounted tight, something will be leaking
mike
Other things I've seen done (if there's access) are weld/braze/solder the allen key in the bolt or even Araldite glue and left overnight in one case!
Good luck!
I thought of doing this last night, but if it's as tight as the others, I'll just tear the head up.
I have a Snap-On left handed drill bit and bolt extractor set.
Looks like it will fit, but I will investigate it further.
In the plans.
like fuel line? Yeah, sorry.
Not vapor locked, but sludged up screen.
mike
Still afraid to break something.
Thanks guys for the suggestions. I will report back when I've fixed it or made it worse.
