A better bag mount?
Old May 19, 2012 | 02:57 PM
Jclind1966's Avatar
Jclind1966
Default A better bag mount?
I've had my 86 Electra Glide Classic for 6 weeks now and have most of the bugs fixed. The bag mounting system (factory pins) is easy to use and makes removal a snap, but the bags are loose and the rattle ( a lot ). Is there a better or more secure mounting system available other than bolts, rubber washers and nuts?
Old May 19, 2012 | 07:20 PM
Gunslingertom's Avatar
Gunslingertom
w
I use one of the factory twist fasteners and one allen bolt with a speed nut.
Here is the inside of my right bag.
And here is the speed nut on the back side. I used rubber fender washers and when I took this pic, I was using tire patch cement and it didn't work too well. Now I have contact cement and it is holding up well.
I do it this way, because one morning when I got to work, I was getting my lunch out of the left bag and noticed that one of the twist locks had come out. I was worried about losing a bag, so this seemed like a viable alternative.
Old May 19, 2012 | 07:47 PM
Dr.Hess's Avatar
Dr.Hess
Yeah, that twist lock system was not a good idea. Slightly better than the crap that was on shovelheads, but still had problems. I fixed mine with a 1/4"x 20 phillips head screw and a bent plate on the fender side with a nut welded to it. I should have done that on Day 1, not after almost 20 years. I have not had a single problem with it since.
Old May 20, 2012 | 09:58 AM
grbrown's Avatar
grbrown
I replaced my twist-locks with similar threaded clips to the one Gunslinger shows, with domed allen head screws. I use shallow rubber washers between bag and mounting, with a dab of blue loctite on the threads.
Old May 20, 2012 | 10:06 AM
NAILIT RK's Avatar
NAILIT RK
The twist fasteners are called Zeus fasteners and have been used on airplanes and race cars for years. You can tighten the connection by spreading the spring a tad with a flat blade screw driver and using a flat rubber washer can help take up some of the slack (oem equipment on my 01 RK) Also make sure that both rubber 'bushings' are present on the bottom of the bag the bushing can fall out when removing the bag and go unnoticed.
Old May 20, 2012 | 10:27 AM
RidemyEVO's Avatar
RidemyEVO
Although mine don't rattle they will shift if I grab them. I have a bolt going into a a u shape nut , sorry not sure what there called.
Old May 20, 2012 | 01:23 PM
Dr.Hess's Avatar
Dr.Hess
They are not Dzus fasteners. They are Cheap Crap Fasteners. Dzus fasteners lock in on a wire like piece. These have little ears that try to grab a thin piece of sheet metal that gets loose.
Old May 20, 2012 | 02:18 PM
Gunslingertom
Exactly!! I owned a front engine dragster full of Dzus fasteners. NOT the same thing.
Kraig76
2014-2024 Touring Models
56
May 31, 2015 07:06 AM
Jetfever
Feb 23, 2015 12:23 PM
goutieboy
Audio Systems
Feb 3, 2014 07:00 PM
The Borg
Sep 3, 2013 12:52 PM
harleyheaven
Jan 16, 2012 11:39 PM
