Random problem when starting
Old Jul 25, 2012 | 08:45 PM
  #61
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Originally Posted by Gunslingertom
Can you not find a 12 volt soldering iron? How 'bout a butane pen torch with soldering tips. I have both of those and they both are quite handy when electricity isn't available.
I have never seen a 12 volt soldering iron but it sounds interesting.
As for the butane pen torch, all the joints in the jumper wire to be soldered would be right on top of the battery for us.
Not a place I want to be soldering with a butane pen torch.
Old Jul 26, 2012 | 09:59 AM
  #62
Nostalgia_93's Avatar
Nostalgia_93
Thanks! I´m not usually soldering things for the bike, but good option in the future if needed. Didn´t know about battery-powered soldering irons.
I´d like to have one like the Weller:
Cheers,
Old Jul 31, 2012 | 01:26 PM
  #63
Nostalgia_93
Hi guys!
Very hectic here during these days! will install the wire as soon as I have some free time to do it real soon.
Here's the prepared wire, I added a double layer of thermoretractable tube in the center to make the union even more rigid and secure.
No mystery here, but will let you know how it went when installed :-)
Cheers,
Old Jul 31, 2012 | 02:30 PM
  #64
miacycles's Avatar
miacycles
You might want to put a little tubing around that bare metal spade connector. Once the other end is hooked to the battery it will be hot and can short out!!!
John
Old Jul 31, 2012 | 02:53 PM
  #65
Nostalgia_93
Thanks miacycles!
It's naked because it'll be inserted substituting the actual 30 spade connector on the plastic block piece that connects to the relay, as explained by texas ;-)
Cheers,
Old Jul 31, 2012 | 03:17 PM
  #66
texashillcountry
Dirt don't hurt
Originally Posted by Nostalgia_93
Hi guys!
Cheers,
That is exactly how I wired mine. If you want a little extra insurance that the connector won't come loose because of bike vibration wrap a cable tie around the relay and connector block over your new wire.
Old Jul 31, 2012 | 06:30 PM
  #67
Nostalgia_93
I'll do it, thanks!
Old Aug 1, 2012 | 09:33 AM
  #68
miacycles's Avatar
miacycles
Thanks miacycles!
Cheers,
Good the block is the way to go!!!
John
Old Aug 1, 2012 | 10:52 AM
  #69
Lakerat's Avatar
Lakerat
Way less trouble and cleaner than adding a second relay. Hope it works for you Nostalgia. What gage wire are you using?
Old Aug 3, 2012 | 10:30 AM
  #70
Nostalgia_93
Hi guys!
Just installed the wire and all went great, the bike starts better than ever. Feels like it has gained more strenght and a few fractions of a second in the starting process.
Following picture shows the removed 30' spade connector before insulation, thanks Texas!
Thank you very much D1gger, Texas, Gunslingertom, miacycles and all of you guys helping out!
Cheers,
Thanks, it worked! About the gauge, don't know, but it was rather thick, equal as the wire that came with the fuse holder showed in the previous picture I posted:
Bruce Lines
Shovelhead
Oct 27, 2018 04:44 PM
jeff6898
Sep 24, 2014 08:10 PM
dr.hacknthebush
General Topics/Tech Tips
Sep 10, 2011 08:38 PM
wildside41
Sep 3, 2008 02:05 PM
budder
Jul 9, 2007 09:57 AM
