Air cleaner mounting flange question
Old Jul 15, 2012 | 08:37 PM
Uncle G.'s Avatar
Uncle G.
Originally Posted by Spanners39
It matters very much if the air cleaner isn't bolted to the heads......its the only thing that stops the carby falling off!!
I was speaking of the CV carb being bolted to the air cleaner, instead of the o-ring joint of the Mikuni, and that neither system mattered, as the carb wouold still fall off the manifold if the air cleaner is not bolted to the heads.
Old Jul 15, 2012 | 09:02 PM
97HeritageSpringer's Avatar
97HeritageSpringer
I fixed it today by drilling holes through a pair of 1.25" long 1/2 -13 bolts and using a washer to bolt the air cleaner base to the heads. I rode it about 100 miles or so today and its good now. I do think I am going to get a SE or Big Sucker base to replace the factory A/C base.
I wasn't aware the bike had a Mikuni on it either. I assumed it was the stock CV carb. No one else I ride with has a carb'd EVO bike, so I had nothing to compare it to. The bike runs really well, and I have smoked several 88 cu in TC bikes, and it is on par with 96/6 speed bikes I ride with. It has a Crane HI-4 ignition it as well. It is a 3 owner bike, and guy I got it from didn't know what mods had been done to it. I don't think it has a cam judging by the sound of it, but it does really run good.
Old Jul 15, 2012 | 10:18 PM
Spanners39's Avatar
Spanners39
Sweet, I found the wording of your post a bit confusing but then I live upside down and speak "Kiwi"
Old Jul 16, 2012 | 12:06 AM
j1mmy's Avatar
j1mmy
you cant just bolt the aircleaner to the heads. the engine breathes through them two bolts.it will cause the gaskets to fail and oil will blow out everywhere from the trapped pressure.you should get some stock mounting bolts, or at least drill a small breather hole through the mounting bolts.
Old Jul 16, 2012 | 12:12 AM
Spanners39's Avatar
Spanners39
He drilled holes through the bolts......
Old Jul 16, 2012 | 07:51 PM
Uncle G.'s Avatar
Uncle G.
I can tell it's a Mikuni from the picture in your avatar. That's a good running carb, as I can attest to.
Old Jul 16, 2012 | 07:54 PM
Uncle G.'s Avatar
Uncle G.
Yeah, re-reading it, I can see why you'd be confused. Now I am too.
Nicopag
Carburetor Related
19
Feb 3, 2019 08:27 AM
R.N.CUMMINS
EVO
16
Mar 13, 2017 08:01 PM
800screws
EVO
15
Nov 14, 2016 12:34 PM
jhowle9475
Exhaust System Topics
Aug 30, 2010 05:37 AM
99superglide
Mar 7, 2010 06:25 PM
