Axle adjuster problem
Old Jul 29, 2012 | 04:22 PM
Chopperbob's Avatar
Chopperbob
Default Axle adjuster problem
Puttimg a new tire on my 95 bagged and while putting back the Brake side axle adjuster is loose but not on pulley side I did remove the adjuster and clean it from years of crap on it any ideas is there up and down to them
Need help ASAP please
Old Jul 29, 2012 | 04:33 PM
IronWright's Avatar
IronWright
where your jam nut?????
Old Jul 29, 2012 | 04:42 PM
Spanners39's Avatar
Spanners39
Not sure what you are saying here......is the adjuster still loose when the axle is tightened or is it loose in the swingarm?
Old Jul 29, 2012 | 04:51 PM
Chopperbob's Avatar
Chopperbob
Welded nut is on brake side the plate is not tight against the rear of swing arm like it was before I removed the tire I rode and all feels well if that means anything and the belt is tracking very true as well
Old Jul 29, 2012 | 04:52 PM
IronWright's Avatar
IronWright
I figured he was on bout the adjuster bolt.....thats why i says jammers missin...
Old Jul 29, 2012 | 05:02 PM
Stiggy's Avatar
Stiggy
My right side adjuster is looser than the left also. I adjust the wheel so that the adjuster plates are tight against the swingarm and tighten the axle down and ride. Never a tracking issue with mine either.
JT-FXDL
Jun 21, 2011 05:41 PM
PearlWhiteGT
May 18, 2011 04:07 PM
madcitycustom
Jun 15, 2007 02:55 AM
dynalowride
May 29, 2007 01:50 AM
wadejesu
Feb 22, 2007 07:04 AM
