Anti-seize
Old Oct 22, 2012 | 09:35 AM
jokenroll's Avatar
jokenroll
On a slightly different subject: if you are changing intake seals, change the clamps as well - they are inexpensive but in my experience surprisingly easy to warp (that could be your real problem).
Old Oct 22, 2012 | 10:13 AM
akmorris81's Avatar
akmorris81
As a mechanic in southeast Alaska where we have a lot of corrosion (I live next to ocean) I usually will not use anti sieze on bolts or wheel studs because it makes using a torque wrench or getting the proper amount of torque on bolts inaccurate. I have seen numerous bolts/wheel studs brake when tightening or threads pulled out due to anti sieze. I do use anti sieze regularly, but not on bolts,
iDodgimus
Apr 8, 2012 11:51 AM
cirhere2
Nov 30, 2009 01:06 PM
Demkay
Jun 26, 2007 10:42 PM
vertigo14
May 25, 2007 11:00 PM
dawg
Nov 1, 2006 12:00 PM
