Help with replacing shifter shaft? Expirence? Cost?
On my commute today I busted my shifter shaft off on the tranny . I understand I need to remove the primary to get to the shaft, but is there any short cuts? Or any way to use the little bit of shaft still remaining? The first set of splines snapped off, but there is some left on the shaft.
Just for the heck of it, what do you think this will run me if I have a shop done. And if you have any expirence, was it a terrible mess that would be worth having a shop do it, thanks fellas.
If you take the short cut, keep in mind that the removal of the trap door from the shafts cross loads the trap door ball bearings, and they should be replaced. When you reinstall the trap door, you must pull the shafts into the bearings, not push the bearings onto the shafts, or again the bearings will be cross loaded.
Since you have never been inside a 5 speed transmission, I suggest doing it the conventional way, that way you will know how to remove the primary components, a good job to know how to do.
You can also replace all the seals on the left side of the transmission while the primary drive components are removed.
No need to pull the primary, make it easy on yourself and get back in the wind faster.
In the OPs case he doesn't have a shaft to fit it to but I have fitted the better levers on bikes and they are awesome but its way harder to get the old lever off than anyone will tell you prior to handing over your dollars.
