Chirping?
Old Dec 9, 2012 | 02:31 PM
  #31
Sacarriker's Avatar
Sacarriker
Originally Posted by Spanners39
Ignore it until something falls off.....
I'm already there.
Old May 9, 2013 | 11:32 AM
  #32
Will Hunt's Avatar
Will Hunt
Stage III
Originally Posted by Sacarriker
The bike is a 1994. I have the service manual. Will check it. Thanks.
I have a 1994 Road King. I had a chirping noise just like this when decelerating. When I pulled in the clutch it stopped. After looking at some of the comments and sugesstions on this forum I adjusted the final drive belt tension. It was a little loose. The noise stopped right away. Check your belt tension. Always look at the simple stuff first.
Old May 9, 2013 | 11:53 AM
  #33
jokenroll's Avatar
jokenroll
Both of my bikes chirp time to time - it's the belt. Easy to check - when the chirping is the worst, take a toothbrush and brush each tooth (of the belt of course) and between with MrClean. If there's no chirping after that - that's the cause.
I typically do it once or twice the season, normally I just spray it with mrClean occasionally.
Old May 21, 2013 | 04:35 PM
  #34
utterstan's Avatar
utterstan
thanks my 91 is chirping and its driving me nuts
Old May 21, 2013 | 04:50 PM
  #35
bluharley's Avatar
bluharley
Clean the teeth if they are there. I was missing some, no cure but a new belt.
Old May 21, 2013 | 05:49 PM
  #36
Gunslingertom's Avatar
Gunslingertom
If the drive pulley is worn, all the cleaning in the world won't fix it for very long. It's hard to see, but get a flash light and inspect the drive pulley teeth.
aGoodRogering
General Topics/Tech Tips
Aug 10, 2017 09:15 AM
Roger C6R
Jun 3, 2012 12:40 AM
tincup64
May 19, 2010 10:43 PM
forever young
Apr 20, 2008 07:24 AM
rustyrun
Feb 3, 2008 06:44 PM
