Pinion Shaft snapped EVO
Old Dec 21, 2012 | 08:35 AM
flh04087's Avatar
flh04087
Default Pinion Shaft snapped EVO
ive being having a problem with my pinion shaft nut always loosing up well it did it again so i pulled the nose cone off to find the pinion shaft laying on the bottom of the chest? its a clean break any ideas why this would break ? has anyone else see this ??
Old Dec 21, 2012 | 01:31 PM
Spanners39's Avatar
Spanners39
Not seen but heard of it, sometimes attributed to badly aligned crankshaft.
Old Dec 21, 2012 | 02:32 PM
miacycles's Avatar
miacycles
+1 0n spanners comment. This end doesn't normally break!! Is there something binding up the valve train or oil pump????
John
Old Dec 21, 2012 | 02:39 PM
flh04087's Avatar
flh04087
this thing ran so smooth i think the bottom end bearing gave up and thats why i was having such a problem i guess i will know what happened when i pull it down i have a new 92 bottom end already so im changing the oil pump and drive , cam and lifters so i wont have the same problem hopfully
Old Dec 21, 2012 | 03:10 PM
chopperb1's Avatar
chopperb1
I never seen it happen on an evo. I had it happen on my ironhead once. Nothing was locked up in the motor or trans. Never did find the cause.
Old Dec 21, 2012 | 04:57 PM
Uncle G.'s Avatar
Uncle G.
The only cause I can think of would be either a bad alignment problem with the crank, or the introduction of a foreigh object into the cam or oil pump gears, like maybe a piece of a tappet roller needle.
Old Dec 21, 2012 | 07:36 PM
flh04087's Avatar
flh04087
What is a bad alignment with the crank?
jsrracing
Milwaukee Eight (M8)
26
Nov 8, 2018 06:52 AM
Hannibal Smith
Shovelhead
Jul 23, 2018 03:15 PM
portlandron
EVO
20
Sep 21, 2016 06:48 PM
Papa Jack
Engine Mechanical Topics
11
Jan 16, 2015 06:27 PM
Cassanova
Exhaust System Topics
Aug 20, 2008 09:34 AM
