I finally found the cause of the under the seat vibration I reported in other posts. Today I noticed an unfamiliar space between the rear right wheel spacer and the hub. I wanted a good thread to use as a guide to replacing the bearing, does anyone know of any? the search I performed did not produce any that I could see.
I have seals on hand but will have to order the bearings or pick them up at the bolt and bearing dealer here. I could not determine from the manual the length of the spacers. Do I need to go to the dealership to get that info?
