Replacement ignition
Old Feb 22, 2013 | 12:56 AM
Gra490's Avatar
Gra490
Default Replacement ignition
have a 85 Evo that is giving me grief and pretty sure it is the ignition. If I were to replace the system what is the best way to go. I want to keep it simple and reasonable priced.
Old Feb 22, 2013 | 05:16 AM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
What sort of grief are you getting?
I have heard good things about twin tech.
Old Feb 22, 2013 | 05:46 AM
grbrown's Avatar
grbrown
Be certain to identify the actual source of your problems. On my 1990 it proved to be the sender unit inside the timing cone, the ignition module was fine.
Old Feb 22, 2013 | 03:27 PM
Gra490's Avatar
Gra490
I am sure it is the sensor plate inside the cone but if I am going to replace it i want to do it right. Not get a new plate that then needs another module because they dont suit.
Old Feb 22, 2013 | 07:28 PM
Rob85WG's Avatar
Rob85WG
For maybe $150 you can get an Ultima that has programmable switches and is PC programmable as well. Some people love them, others complain about some Chinese components. I have had one for 5 years with no problems.
Here is some info:
Old Feb 22, 2013 | 08:38 PM
Dr.Hess's Avatar
Dr.Hess
Are you using a HD module? Then get a HD sensor plate and don't worry about it.
Old Feb 23, 2013 | 08:26 AM
captsluggo's Avatar
captsluggo
Originally Posted by Rob85WG
For maybe $150 you can get an Ultima that has programmable switches and is PC programmable as well. Some people love them, other complain about some Chinese components. I have had one for 5 years with no problems.
Here is some info:
http://youtu.be/a67_mYWhFT4
I use one of these as well with no problems so far. (2 years) I went through 2 HI-4 units over about 6 years.
Captsluggo
Old Feb 23, 2013 | 11:23 AM
NutterFLH's Avatar
NutterFLH
Had Crane Hi-4 that broke down at the module, replaced with OEM that broke down at the sensor plate. Now I run Dyna S single fire connected to the old Crane Hi-4 coil. Works good and it`s cheap and simple. It requires a mechanical advance unit. Have a look at their website. It might be the system You need.
Old Feb 23, 2013 | 11:51 AM
texashillcountry
Dirt don't hurt
This is good advice!!!!!!!!!
Old Mar 1, 2013 | 05:53 AM
imrotton2's Avatar
imrotton2
im running the compufire elete one,,, has tunable advance and, rev limiter,voes
mr-stabby
EVO
24
Nov 15, 2018 05:44 PM
1993FXSTS
Jun 5, 2017 05:37 AM
rouskie
Ironhead
Mar 20, 2017 10:14 PM
tonycap
EVO
Apr 20, 2013 09:30 PM
Booey424
Sep 27, 2007 07:40 PM
