1990 FLT ex. Police with 70,000 miles .
New to HD. Ex. Big Wing wrench.
Newly purchased , have not ridden yet . Runs very good in driveway.
Changed the oil to 20/50 and it seems to smoke from both sides now.
Have learned that the Big Evo can use oil if it feels like it etc., ok .
Im learning that the valve lifter / tappet needle bearing rollers in the EVO can fatigue and fail resulting in a major **** storm of $$$ .?
Have seen many differing opinions about this and i am now wondering if a consensus can be offerd by those in the know .?
So... does anyone out there actually know how long a EVO will go before a rebuild is advised ?
Spanner, can he here the rollers with a stethoscope at the bottom of the guide tubes. I know on my TC, all I here is a steady smooth hum with no click or erratic type bearing tic but I have see a lot of roller lifter on here with the roller bouncing around. Just seem like you would hear it or is it the shaft is worn and the little rollers still in good shape?
If it were mine I would change them out to the later "B" lifters like Spanners says. She will be good for another 80,000 if you treat her right. Many go well over 100,000 without a rebuild if the little things are done. Yours still has the good cam bearing, so that should not be a problem.
Do a compression test. If it fails, do a top end. If it's good, it's probably valve seals/seats. Like Spanners says.... it may stop anyway. I'd probably just ride. She's old enough to smoke.
Lifters can grenade with no warning, even if they are still working its too late once they are noisy as the cam surface gets all chewed up. I recommend lifters at 40-50K miles as a precaution....even on TC's.
From personal experience, by the time you can hear the lifters, the damage is already done. That means the needles have already fractured, and pieces of hardened 6150 tool steel are circulating in the motor. The results will not be pretty. I had one fail at 46,000 miles, and it ended up costing me a motor.
Current motor runs like a champ at 85,000 miles. Good compression and negligible oil consumption. I change lifters at 40,000 mile intervals. Maybe it's overkill, but it DID happen to me once, so....
Thanks to all .
Ive found an apperantly reputable HD approved shop and have decided to do a top end rebuild including a mild mid range cam " Andrews EV 27 or such " and maby a head shave to bump up the compression slightly. Im a little confused about the choise of replacement lifters .? After much trolling through the sites etc. im down to what i believe to be HD " B " lifters or the Johnson lifters found on the " toys for boys " site .?
Im getting on and this ole girl will probably be my last bike purchase .
Any advise is appreciated .
