Evo Hugely Underpowered?
Old Apr 3, 2013 | 10:32 PM
JKay's Avatar
JKay
Default Evo Hugely Underpowered?
Went to see a.1997 FXSTC today with the intent of a possible purchase. Looked mint apart frm a small dent
However it felt massively underpowered. Maybe only had power up till 2-3000 rpm then nothing. Couldnt get past abt 40 mph.
Any ideas on what this may be? One point to note is that its been sat (with oil and fuel in) for 8 years
Thanks
Old Apr 3, 2013 | 10:40 PM
Noxx's Avatar
Noxx
Carbs full of varnish. Starving at full throttle.
Old Apr 3, 2013 | 10:49 PM
JKay's Avatar
JKay
Ah so if its just that then should be an easy enough fix.....
I certainly hope its that and nothing major as apart frm that I really like her and hope this purchase happens
Not sure what else could be the cause apart frm that
Thanks
Old Apr 3, 2013 | 10:52 PM
the blob's Avatar
the blob
Gota be the main jet plugged up, as my.evo fxtc can break the ton fairly easy.
Old Apr 3, 2013 | 11:15 PM
Shortmag's Avatar
Shortmag
Clean the carb-new gas and plugs and hang on for the ride
Old Apr 3, 2013 | 11:29 PM
Beemervet's Avatar
Beemervet
That's all well and good, but use it to your advantage when dickering over price.
Old Apr 4, 2013 | 12:15 AM
Noxx's Avatar
Noxx
Yep. Also figure you're going to need tires and hoses, pretty much anything rubber. I'd bet the intake mani gasket looks like cheesecloth. GL with it, sounds like a find.
Old Apr 4, 2013 | 12:25 AM
JKay's Avatar
JKay
Thanks all.
I plan to get it looked at properly get everything thats need changing changed, torrington cam bearings, Andrews Cam and Ill be a happy man
Noted on the inake mani gasket will have a look for sure thanks
Old Apr 4, 2013 | 06:06 AM
JKay's Avatar
JKay
Old Apr 4, 2013 | 06:08 AM
JKay's Avatar
JKay
