secret to carb install
Old Apr 29, 2013 | 11:00 PM
RidemyEVO's Avatar
RidemyEVO
Default secret to carb install
Hi guys, I have to do some work on my wifes bike, the 89 Heritage with original Carb and stock breather setup. My bike has the cv carb and is super easy to pull off and install, hers looks to be a real pain. Is there a trick to installing the carb to the intake that you's can pass on to get a goos seal? Bike starts good with enrichener but needs the need replaced as it overflows sometimes when fuel shut off is left on with bike off.
Thanks
Old Apr 29, 2013 | 11:06 PM
Road Star's Avatar
Road Star
Talking
Don't mean to hijack this thread... however, I was wondering why the CV carb is so much better, than a Mikuni or other.
Thinking about getting one for my EFI to carb conversion; $295 a pretty good price?
Old Apr 29, 2013 | 11:15 PM
RidemyEVO's Avatar
RidemyEVO
I don't know for a fact if cv carbs are any better but you may notice all harleys up until the efi have cv carbs.
If your going to look into a cv carb for your bike get a hold of Dale for his Killer Carb you won't regret it.
Old Apr 29, 2013 | 11:31 PM
Road Star's Avatar
Road Star
Did a quick search, is this the guy?
http://www.ebay.com/itm/HARLEY-DAVID...-/270620924203
Do you have another link? Is he a member or Sponsor here?
Thanks!
Old Apr 29, 2013 | 11:34 PM
RidemyEVO's Avatar
RidemyEVO
Yep tats the one. Do a search now in hdforums and you'll find out lots of good info.
Old Apr 29, 2013 | 11:40 PM
Road Star's Avatar
Road Star
Awesome! Thanks. Good luck with your project.
Old Apr 30, 2013 | 12:33 AM
Spanners39's Avatar
Spanners39
Thanks
If its got a Keihin butterfly the trick is to get a mirror and some emery and rub the mounting flange down until its properly flat. Then reinstall with new gaskets and some Hylomar and don't over tighten the flange or it will leak.
Patience and attenton to detail is all it takes....gotta love the push-in CV mate!
Old Apr 30, 2013 | 12:34 AM
Spanners39's Avatar
Spanners39
CV is dead simple, bits are cheap and there is heaps of info re jetting etc....they also economical compared to most aftermarket ones.
Old Apr 30, 2013 | 08:08 AM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Thanks
My S&S did the same thing till I reset the float level.
Old Apr 30, 2013 | 08:55 AM
RidemyEVO's Avatar
RidemyEVO
I'm a believer that float levels don't generally need to be reset unless the float needle has deteriated and in that case just replace the float needle.
