Got a problem
Old Jun 13, 2013 | 02:14 PM
Doug S's Avatar
Doug S
upgrade to the roller bearing ASAP
Spanners, Thanks, is this a big deal, sounds like there would be more to it than just changing the bearing itself.
get it, ride it awhile, then you'll know which bike to keep
Yeah, that's kind of the plan right now, I was up early this morning cleaning up the garage and figuring out where I can hide enough stuff to get another bike in there. Needs to be done even if the bike falls through...
Thanks to all for posting about something so off topic for this place..
I did not know about the balanced motor, are all twinkies balanced? A guy at work has a newer ultra and at idle that rubber mount motor bounces around like a childs toy. I did know that fuel injection was out and the tensioners wear quickly. I've been looking Primarily at EVO's but they are usually more money and/or higher mileage or a color I can't live with so this color twinkie with a carb was my next best bet.
Any comments appreciated, I'm usually pretty decisive but this had me wavering....
Ds
Old Jun 13, 2013 | 02:45 PM
jokenroll's Avatar
jokenroll
Only TC softails are balanced. Other twinkies are rubber-mounted, and have a couple of hp more supposedly.
Old Jun 13, 2013 | 05:10 PM
grbrown's Avatar
grbrown
That comes from the fact they don't have the balancers, which use up a bit of power.
Old Jun 13, 2013 | 06:47 PM
Spanners39's Avatar
Spanners39
Ok, more info:
1: its a myth that balanced Softie motors don't vibrate....they do, they just don't bounce around in the frame at idle because they are not rubber mounted
2: The rear outer cam bearing upgrade is just a bearing swap....re shim the outer sprockets on reassembly....all good....but it takes a while as it requires the rocker gear to be pulled but that's way easier than on an Evo.
Old Jun 15, 2013 | 03:15 PM
Doug S's Avatar
Doug S
Well, I'll probably not find a cleaner one, completely stock, very small chip bottom of the rear fender and RH fishtail was heavily buffed, probabley a little rust that was cleaned wrong.. Rides nice, shifts well, motor runs smooth but it's a complete dog in the power department. How did they even sell these when they were new? We are 500 dollars apart, he wants 10K...What do you think?
Ds
Old Jun 15, 2013 | 06:53 PM
ironoxide's Avatar
ironoxide
Default Your call
Well Doug, the dollars in your bank account are only worth what you and your family think they're worth. I don't sweat 5% on a deal, if I really want it. Life is short. We all can spend $500.00 going to a ball game, yes?
Doug, don't tell your wife I said that. I'm not the devil here.
By the way, the Hawks are going to smack Boston again tonight!
Old Jun 15, 2013 | 07:33 PM
ironoxide's Avatar
ironoxide
Originally Posted by PanHeadRich
You'll be hard pressed to find a finer machine than the Heritage Springer. I have the Evo version that I bought new in 1997. In the past 16 years I've rode it hard through many canyons and twisted roads and they handle great for a big cruiser. On the open road they're as comfortable & smooth as can be. They can be a great classic looking bar hopper, or full on touring bike. They're comfortable enough to spend all day in the saddle, and do the same the following day. They're truly a magnificent machine.
Unfortunately I can't offer any first hand opinions of a TC being that I don't have one.
There is a forum exclusive to the Heritage Springer where you can get a wealth of information from many devotees with first hand experience of this machine. Just about everything you would want to know. They're a real friendly and helpful group as well. I'm sure it can help you make your decision. Check it out at: http://www.heritagespringer.com/
Good luck with your decision
Pan owns what I think is the finest Harley they ever made....period...wait, maybe I should include the FXR. Okay, enough said!
elie2000elie
EVO
19
Mar 24, 2018 09:10 PM
Budda568
Jun 20, 2017 06:16 PM
Ugly's 98HD
EVO
Sep 30, 2009 08:55 AM
Tucker99
EVO
Mar 21, 2007 02:34 PM
kanshusker
Exhaust System Topics
Oct 25, 2005 05:18 PM
