1989.5 and up Starter Shenanigans
Old Jul 8, 2013 | 02:14 PM
Joker's back's Avatar
Joker's back
Default 1989.5 and up Starter Shenanigans
1990 Softail
(parts manuals don't show squat for '89 or '90, but they should be like the '91 which DOES show up in parts manuals)
Symptom: starter solenoid engages, motor turns over and fires up. Starter stays engaged. Kill ign, motor dies, starter keeps moving crankshaft.
Kill starter by arcing hot solenoid/starter terminal against starter case.
Culprit: The solenoid plunger is sticking due to contacts being pitted and arcing. They need replaced or refinished.
Here's 3-d operations for the concept:
Here's the solenoid for a Dodge Ram which is the same as what you have on your Harley so you see what's involved:
This is the kit you would need to replace pieces if you didn't want to clean them up and resurface the faces with some emory cloth:
http://www.ebay.com/itm/REBUILD-KIT-...9bd7a2&vxp=mtr
.....or any of the hundreds of kits like it.
If you're dead-clicking or if you're dragging the starter, disconnect the negative battery cable, back the 3 screws off the endplate peeking out just under the oil tank on the right side, pull the plunger and start looking for pitting on copper mating surfaces.
Friendly, free advice. - Joker
Old Jul 8, 2013 | 06:24 PM
LowriderHarold's Avatar
LowriderHarold
Have one question. Can you replace all the parts, that is shown in the rebuild kit, with the starter still bolted to the primary? I need to do this, but can wait till cold weather if ya have to pull the starter completely out to replace the internals. This is for a 96, FXDL.
Ride Safe,
Harold
Old Jul 8, 2013 | 07:32 PM
Uncle G.'s Avatar
Uncle G.
On my '94 Softail (probably typical of Evo Softails with unitized starters), I could replace the center plunger and the upper contact (had to alter a 14mm socket so I could turn it with a wrench through a hole in the oil tank). I couldn't remove the lower contact with the starter in place.
Old Jul 9, 2013 | 06:41 PM
Joker's back
Yeah, to do the job right and not have to get back into it real soon, you have to replace all the components of the kit. To do that, out she comes.
Old Jul 9, 2013 | 11:03 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Ride Safe,
Harold
Hell man just do it on a rain day.
It don't take that long to pull a starter.
75hdxlh1000
Nov 16, 2017 12:16 PM
97Heritagerider
Electrical/Lighting/Alarm
Apr 16, 2017 08:26 PM
Chummers
General Topics/Tech Tips
Aug 26, 2013 12:06 PM
MMCHD
May 17, 2012 08:06 AM
pd76
EVO
May 7, 2012 07:22 PM
